The ACPPS turns on when the computer powers the 5V for the USB ports, so most likely as soon as the computer powers on.
If you disable the USB ports they will not be available to windows to use.
Does the amp pop when the computer powers on or when the sound card is activated by the computer (drivers load)? Most likely its when the sound card first recieves power.
Making a guess, your amp should have a delay built into it, right? If the sound card causes the pop when it powers on, the amp startup delay might be enough.
In your current configuration the amps are enabled by the ignition, right? In that configuration the amps power on and are past thier delay when the computer powers on, after its start up delay. In that case the amp is outputting sound when the computer power turns on and the pop can make it through to the speakers.
If the amp is triggered by the 12 output of the ACPPS both will star at the same time. The sound card should make its pop, and the amp delay should cover that up. Since they both will recieve power at the same time the pop should happen before the amp is outputting any sound.
From what I understand about your system, yes.
A work around for that would be adding a Relay between the ACPPS and amp. Use the ignition accessory power to flip the relay, allowing the 12v ouput to be connected to the amp enable only when the ignition is on. In this way both computer power and ignition state have to be present for the amp to be on.
Here are the three states:
1. When the computer is off the amp enable signal would be missing and the amp turned off, reguardless of the ignition.
2. When the computer is on but the ignition is off the enable signal couldn't make it from the ACPPS to the amp because of the open relay.
3. When both are on the amp should be powered for normal opperation.
Hope this helps, please post again if you have any further questions. this is great stuff to have in the thread.
Jesse
