placed an order through the website 2 weeks ago.
just got it today
Just got the power supply installed this past weekend. After a little mis wiring, got it working perfectly, actually made wiring up the HD radio I was also installing super easy.
2 small suggestions that aren't really a big deal, but would have been a little helpful was 1.) not making the removal fuse flush with the casing , made it a bit difficult to remove while I was trying to figure out my wiring mistake without causing a short (or make the opening wider to get a needle-nose in it). 2.) It would be nice to have the same amount of ground ports as 5v power ports (not really a big deal since they are all connected anyways, but would have made wiring easier).
just got it today
I hope you're checking this site. I want an ACPPS but the BUY link on your site doesn't work.
Just come across this thread while looking for something to power my hubs and this seems exactly what I need. Earlier you mention a version that does 5V@10A but the one on your site says 5V@8A does the 10A version have to be specially requested?
I need to run 3x5v devices at about 2.5A each do you have a wiring diagram that would show me how to do this?
Also what made you use a USB B socket rather than a standard one?
Just had a thought as this product won't work for me as one of the devices I wanted it to power is the carpc itself which can't be on without your device being on and vice versa.
