Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 116
Thread: USB Syncroized 5V@8A power supply POL. Now Taking Orders!!!
  1. #31
    Jun 2007
    Tampa, Fl
    I am in the final stages of my install and running into a problem with the number of usb devices I am attaching. The voomPC has only four functional usb ports. Of the most common devices attached via USB, which ones are most likely to need a powered hub? I would like to try to use the hubs without a power supply first and then power them later if it becomes an issue. Off the top of my head, here are the USB devices to be used:
    VGA monitor with touchscreen
    Sirius USB connector to tuner
    GPS (probably will not work thru a hub)
    TV Tuner
    cell phone as modem/charger (probably needs to be powered)
    Space Explorer 3D mouse
    DVD player
    mini Keyboard
    HD radio tuner
    Before the development of this product, how was lack of usb ports addressed? Thanks for the input!
  2. #32
    Low Bitrate Beehphy's Avatar
    Apr 2007
    Quote Originally Posted by inh View Post
    $80 for a kit.. This is using SMD components, right? Soldering those has got to be a *****..
    My productis not a kit. It is a complete and funtional product. plug and play.
    And yes, soldering SMD components is a bi@tch! thats why it takes me 4-5 hours to build each one. soldering, machining the chassis and assembling.
    Quote Originally Posted by ReefDonkey View Post
    TV Tuner
    DVD player
    mini Keyboard
    HD radio tuner
    The lack of USB ports was the reason for the design of this product. I too had way to many USB devices to run off the 4 standard ports.
    For your install I have caatogoraized each piece
    Lower power (minimal current draw, could be together on 1 unpowered hub)
    VGA monitor with touchscreen (should only be powering the touch logic not the screen)
    Sirius USB connector to tuner (just communications, the tuner has own power feed)
    mini Keyboard
    High power: (close to 0.5A draw)
    DVD player (motor draws a lot on startup)
    GPS
    TV Tuner
    cell phone as modem/charger (cell phones pull all they can to charge)
    HD radio tuner
    BTW, my psu (either version) draws almost no current from the usb port to turn on, so it could be plugged into a port on the nonpowered hub
    So, that means you need 6 ports, or add 1 powered 5Pt and 1 unpowered hub 5pt.
  3. #33
    Jun 2007
    Tampa, Fl
    Are you still in the pre-order stage or do you have a product to ship? Either way, count me in. Nice work!
  4. #34
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    My mistake, I read that $80 gets an unassembled supply, with manual. Whoops!
    I'm in =]
    cashtexts - Earn money for receiving text messaged offers
    cashtexts review not a scam
    Space Navigator - 6 Axis input device: Take it apart - Driver App
    RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
  5. #35
    Apr 2007
    11/16 UPDATE
    The redesign of the 10A version with switched unregulated 12V output is complete. I should still be able to sell finished products for $80. And I may make kits available for $50.
    The redesign changed the location of some of the connections. But all serve the orrigional purposes. the "12V" connections are the power input, remote is a 5-50V enable signal input, switched 12V, GND, and 5V are self explanatory. The USB-B plug is also a 5-50V enable signal input. It still has power good, and fail LED's between the USB and screw terminals.
    Now i have to round up $100 to build the prototype, 5hrs to build and spend 20hrs testing. I'll keep everyone updated on the progress.
    Would anyone like to see a model with a regulated 12V output? A 2-5A 12V output would probably add $20 to the price.
  6. #36
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    I would LOVE regulated 12v.. Perfect for powering the LCD
  7. #37
    Low Bitrate thatslife's Avatar
    Mar 2007
    Miami,FL
    I would agree regulated 12v seems like your going to have many models of this..
    but to make sure the the 12 power inputs are from battery and switched 12 could go to a lcd that can handle unregulated 12. Dont understand where the remote goes to
  8. #38
    Nov 2007
    So a unit with regulated +12V and regulated +5V would cost $100? How is that different from this
    http://store.mp3car.com/CarNetix_CNX..._p/pwr-012.htm that also includes a fan & shutdown controller for $95?
  9. #39
    Apr 2007
    Quote Originally Posted by jakegem View Post
    Mine wouldn't have a fan..? Thanks for pointing that out. I would have been angry if I had developed it for no reason.
    Actually My design would have provided more current on the 5V rail and less on the 12V. Probably 5 and 5. I wouldn't have a startup/shutdown controller because it simply follows the computer. My design assumes you have a computer that has that controller built in.
    Quote Originally Posted by thatslife View Post
    Thats 3 models I proposed
    5V, 10A with switched 12V unreg output. 80$ for sure.
    5V, 5A bare bones ~$55-70 (design not finished yet)
    5V, 5A + 12V, 5A ~$95-105 (design not finished yet)
    I could cheaply add a LDO regulator for the 12V regulated ouput, but the problem is, I couldn't guarantee the output would function when the engine is off. The alternator in your car holds the 12V system at ~13.5-14.5V, enough to regulate 12V using a LDO regulator. but on battery alone the cars 12V falls to 12.5V and below, not enough for the LDO to reliably work properly. I could try to simply turn the 12V off if there's not enough to maintain it properly, but that would be a hack solution. also large hits from your subwoofer amplifier would probably cause that output to cut out even under engine power.
    The remote is an input. you can use the USB plug or the remote input to turn this power supply on. either input can handle a 5-50V input signal to turn on.
    Say your setup uses all your avalable USB ports, with none to signal the power supply to turn on. You could splice into the computers 12V rail or the keyboard port (5V) to trigger the power supply to turn on.
    Basically what I'm saying, Any time the 5V pin in the USB port or the remote signal raise to 5V, the power supply outputs 5V and the 12V unregulated output turns on.
    Application note: You could use the switched 12V pin to turn on your amps with the computer.
  10. #40
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    Sounds like it's time to build one PCB, with modularized sections for 12v unregulated and 12v regulated output areas
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. -5V power supply
    By gizmomkr in forum General Hardware Discussion
    Last Post: 05-30-2007, 03:00 PM
  3. USB GPS on a PS2 Power Supply
    By mgeorgiades in forum GPS
    Last Post: 04-28-2006, 10:29 AM
  4. Replies: 6
    Last Post: 04-24-2005, 09:32 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
