I got another question via PM, it goes like this:
whats the bit in the troubleshooting section of your manual about the non powered hub latching the 5V power supply on?
Answer:
the problem I ran into to was using a "self powered" hub that happened to have a power input port on it. it was not a "powered hub." I supplied power to it using a simple 5v linear regulator and found out that it was causing the 5v regulator to stay enabled.
the computer would shut off as normal, but the 5V system would stay on. the regulator was sending power to the hub, the hub was sending that power into the computers USB ports and back out the USB port the enable signal was using. it had latched itself on but it would turn off when I pulled the USB from the hub to computer.
the fix was cutting the USB cable open and soldering in a diode to the 5v wire. that stopped the power going into the computer. when it shut down there was no way for the power at the hub to make it around to the enable signal.
The computer took no damage and still functions to this day. Also I only experienced this with one of the two hubs in my system. the other had a diode built into it, it was labled a "powered hub" the offender was labled a "USB or self powered hub".
I suppose the problem could also have been fixed by simply cutting the 5v line in the USB cable (usually red) and insulating it so it couldn't short out. I am working on making a small adapter that plugs inline with the usb port adding the diode, solving the issue.
the problem is the 5000qty order they want for male type A connectors (like those on USB flash drives), the female type A (computer side ports) are easy to come by. I just need to find a low quantity distributer.
Maybe I can make a version of the ACPPS V1 that routes the USB data signals from the computer to the hub but stopping the 5V from back feeding, making thia a non issue. but making the adapter would be way easier and universal.
