I have spoken with Victor and it sounds like he is going to be using the remote enable input in his install since he doesn't want to use one of the two USB ports his computer has. He is also going to be using the accessory output to provide power to his screen. (it takes 10-20V input).
Vitorio bought an ACPPSv1 last night and he is also using the carnetix 2140 in his install. S4per, you guys might want to talk about how this could best be hooked up using that power supply and report back.
The Remote enable works exactly the same as the USB enable. when 5-20V are applied to this pin the ACPPS will turn on the 5V and the accessory (12V unregulated) outputs.
