View Poll Results: Would you be intersted in a USB amp as described?
Voters
26. You may not vote on this poll
  • No, not at all, you can put it where I think!
    3 11.54%
  • Only if it was really cheap, say $50
    10 38.46%
  • Only if it was cheap, about $100
    5 19.23%
  • This is the thing I was born for, send me one now!
    8 30.77%
Page 7 of 14 FirstFirst 1234567891011121314 LastLast
Results 61 to 70 of 135
Thread: Small and simple USB audio amp anyone?
  1. #61
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by durwood View Post
    Plastic, steel, aluminum? Perforated? Does it need to dissipate heat or just be allowed to breathe for air circulation?
    It'll be aluminium, with an external heatsink to dissipate the heat from the amplifier.
    Quote Originally Posted by americasfuture2 View Post
    wow, this looks to be a great idea! how or will this work with a audigy nx 2? i cant sit here and read every post right now as i am at work, but how does it receive audio to be amped and output? a line in? or is it all through usb?
    Thanks for the heads up.
    You won't need a sound card (internal or external) to be able to use the amplifier, it's got a soundcard (DAC) integrated! Control (volume, mute) and audio is sent over USB from the PC.
    Joachim
  2. #62
    Feb 2006
    Quote Originally Posted by JC-S60 View Post
    Joachim
    It also has a line-in analog input...
    Diogenes.
  3. #63
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by Diogenes View Post
    Diogenes.
    ...that only works for sending sound to the PC (for audio sources outside of the PC).
    All audio that comes out of the speakers comes out of the internal DAC. If it first enters the line-in, it is sent to the PC and is then played back by the DAC (this way volume control, equalizer, time shifting are also possible on line-in audio).
    Joachim
  4. #64
    Aug 2007
    So can some buy one without the housing?
  5. #65
    Dec 2007
    Chandler, AZ
    Thanks for your interest!
    We're still waiting for the housing company to come up with something acceptable...should be soon.
    @ubersoph: For bulk pricing without housing, shoot me an email: joachim.christiaens@xtronic.be.
    Joachim
    I sent you an email and you never responded???
  6. #66
    Dec 2007
    Chandler, AZ
    guess this topic is dead?
  7. #67
    Mar 2004
    Ghent - Belgium
    I'm sorry, a combination of the end-of-year festivities and me being ill has led to some falling behind.
    E-mails will be answered today!
    On the analog input: if you want, you can use the analog outputs as inputs by sending audio at line level into them. It's not really meant to be used like this but it works.
    A version without housing will probably only be available in larger quantities.
    Joachim
  8. #68
    Feb 2006
    Quote Originally Posted by LivinOne View Post
    no sir,
    just waiting to get the pcb's and the housings so we can put one and two together and test them.
    Housing is to be metal because of heat dissipation of the amplifier chip, so if one wants to buy witout housing one has to provide some heat dissipation.
    Xmas and New year dropping right in the middle of the week does not help when time is short, add a couple down with flu and all gets delayed...
    see if we can stumble back to our feet and get going again.
    Diogenes.
  9. #69
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Will it only have one input? I need a line-in AND a mic input. The line-in I need for my XM unit, and the mic I need for my mic for voice control and Bluetooth phone conversations (the mic must be on the same soundcard as the speakers or there is a bad delay during phone conversations due to latency).
  10. #70
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Wow, great idea. I want one!
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  1. Simple request - USB arrow pad that I can hack up?
    By sivart321 in forum Input Devices
    Last Post: 06-03-2007, 01:47 PM
  2. Wanted : Small, Cheap, Simple PC
    By ukchris in forum Classified Archive
    Last Post: 12-21-2006, 01:44 PM
  3. WTB: Small, simple case for Mini-ITX
    By dmurray14 in forum Classified Archive
    Last Post: 04-03-2005, 09:43 PM
  4. Simple, Small, Audio Mixer? Anyone?
    By techguy in forum General Hardware Discussion
    Last Post: 07-05-2003, 01:45 AM
  5. Special audio preamp circuit
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 06:19 PM
