Page 1 of 8 12345678 LastLast
Results 1 to 10 of 71
Thread: detecting tire pressure
    Jun 2005
    Toronto, Ontario, Canada
    Hi,
    I rented a car last weekend, and it's onboard computer knew the pressure of each tire. I want to put that into my car. Has anyone done this? I figure all you would need is a pressure sensor for each tire, but not sure how you would go about connecting it, i.e. wireless or wired, and power becomes an issue if wireless. Anyway, if anyone has done this, I would love to hear about how you went about it.
    Thanks!
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    A buddy of mine put tire pressure sensors in his Saab. They make kits for it. Pretty slick looking too.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Mar 2006
    Colorado, but Canadian!
    The easiest way to do it is the first way it was done by Porsche. Monitoring individual tire speeds as they rotate.
    An underinflated tire will have a smaller diameter. Smaller diameter covering the same distance, means it rotates faster. Now "faster" is compared to the other tires. You can have up to 3 rotating faster because if all 4 were faster, then they would be the same if that makes sense. So by monitoring each wheel's independant speed, you can detect up to 3 simultaneous low pressure. And since all ABS enabled cars have individual speed sensors already all you have to do tap into all 4 and monitor them.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2005
    Do you have a link to the kit your friend used?
    The speed monitoring idea is good, but I would like to be able to tell the exact pressure of each tire, not just if they differ from one another.
    Newbie colindunscombe's Avatar
    Jan 2007
    High Wycombe
    Tyre pressure sensors in Saab
    Barry I'd be interested in any info you have on this product!
    Regards
    Colin
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    _
    Mar 2004
    Little Elm, Texas
    I wonder how hard it would be to hack that and send the information over serial or the like?
    Jan Bennett
    May 2005
    Lawrenceville GA
    Quote Originally Posted by RedGTiVR6 View Post
    That is what I was thinking, or even via the wireless signals, if you could receive them on the correct freq.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    that is interesting
  1. Computer to control Air Bag solenoids?
    By speedofsound in forum Hardware Development
    Last Post: 06-26-2007, 06:46 PM
  2. Tire Pressure monitoring System
    By sfay93 in forum General Hardware Discussion
    Last Post: 03-29-2007, 07:04 PM
  3. RS232 Tire Pressure Monitoring System
    By jcampbell in forum General Hardware Discussion
    Last Post: 12-11-2006, 06:17 PM
  4. intake/exhaust pressure?
    By dannn in forum General Hardware Discussion
    Last Post: 07-28-2004, 12:02 PM
  5. Tire pressure monitor??
    By claylong in forum General Hardware Discussion
    Last Post: 12-30-2002, 12:32 PM
