I have tried SEVERAL options with the visteon...It is what it is... I live din Phoenix AZ where there is many powerful stations and it was ok. Moved back to PA and I got ONE major station where I was..I am now in Philadelphia and I'm good again... I have tried many things as experiments to improve reception... None seem to have ANY affect on it's performance.
GLASS ANTENNA = BAD!
hari-bhari, YES extending it BAD
keep it away from PC too, PC makes horrid RFI
make sure ur powering up the antenna...
but its NOTHING like a real 30" mast antenna...
Has anyone ever used the antenna amplifier from the subaru's on in a different vehichle, on say the Glass antenna to see if it helps. I had the thought after reading this, thinking about how to get better reception from my glass antenna.
About the only thing to stop me is someone saying they already have and it didn't work.
i used to be in the car audio biz, aftermarket antenna amplifiers NEVER work
are u sure ur powering up the cars ampilied antenna?
fyi, it may NEVER work, and u will be left with 3 options
1. install a mast antenna
2. reinstall the factory radio
3. get a new car
thats the facts... i know u dont like to hear it... but...
now a days #2 works for me!!!
course my car has a mast antenna
search the subaru forums, for aftermarket radio antenna issues
mitch
I don't have an amplified antenna as far as I know, it's a 97 accord. It is a glass antenna, and I know they aren't as good. I thought the subaru's came with one from the factory, and I was assuming it to be a little higher quality, not that I ever had much hope for the concept.
Thanks Mitch.
all glass antennas are amplified (as far a i know)
but sometimes the amplifier is INSIDE the factory radio
the radios Front End, is desigend for the the right antenna on the car
if the factory radio gets good reception... better then the aftermarket
thats a sign
mitch
I have an 04 wrx wagon and it has the glass antenna. I checked and the radio harness has a wire for powering the antenna. I spliced this with a 12v accessory wire; is that the correct way to power it?
My reception was great with the factory head unit.
that should work... white wire in position 14?
http://www.geocities.com/svxdc/WRX-pinout.htm
yea... the factory front end inside the radio, is specifically designed for that antenna
where the HD Radio isnt
look in forums for sabarus where people have attempted to change the radio
see if others complain about antenna
YOU didnt tint the back window did you???? with metalic tint?
http://forums.nasioc.com/forums/showthread.php?t=464212
mitch
So is a DIRECTED DMHD1000s still everyone's favorite for incorporating HD Radio into a CAR PC setup?
Also, can this be completely controlled by a front-end, or are we stuck using the lame display?
the lame display goes in the trash... what would be the point...
RideRunner And Centrafuse both nativly support this tuner
