Page 104 of 139 FirstFirst ... 454949596979899100101102103104105106107108109110111112113114 ... LastLast
Results 1,031 to 1,040 of 1387
Thread: HD Radio Cables READY!
  1. #1031
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    I have a question about antennas. I no longer have a stock antenna in my car, since I did some body work a few years ago that sealed up my antenna hole. Are there any alternative, flat antennas for mounting on the trunk like my Sirius antenna? I just ordered a cable, and can't wait to have radio in the car again after 4 years!!
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  2. #1032
    MySQL Error
    Oct 2004
    for am/fm... prob nothing that will work well
    i have never seen an aftermarket antenna that worked good for am/fm
    and wasnt a mast
    maybe something by fuba, but ONLY use fuba, not some knock off!
    but u might get into impeadance matching issues
    (which is why a lot of fancy oem antennas dont work with aftermarket radios)
    (at least not well)
    it is hit or miss, and that sucks making a hole, then missing
    and without mounting it, u cant be 100% sure
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #1033
    Feb 2007
    Richmond Virginia
    Mitch, I have your cable and have hooked everything up. HD radio is working but I'm having a volume issue. I have searched for a week and still can not find out why my volume level in Hdradio is so high. I have my line in volume set to 1 and my wave line set to 100. Still HDradio is too loud. (I had used mic in with boost off at first and then switched to line in). I used Carwings and DFX4. I noticed that DFX4 installs a HDradio folder directly into Riderunner and Carwings seems to use MJS/Gagets/Hdradio folder. Also the Dll in the dfx4 installed hdradio folder is older (1.1.0.0). I saw that you have software control over the line in from the vistron unit but I can not find out how to lower it more. What file do I need to look for to change it? I have a dual core atom intel board and am using on board sound (Realtek ALC662). Thanks,John
  4. #1034
    Jul 2008
    West Virginia
    Quote Originally Posted by YellowMater View Post
    I am having the same issue.
  5. #1035
    Jul 2003
    Quote Originally Posted by mitchjs View Post
    and wasnt a mast
    (at least not well)
    mitch
    Like this one:
    http://delphi.com/manufacturers/auto...on/fmdiversity
    Current build! Here
  6. #1036
    MySQL Error
    Oct 2004
    i have no idea what dxf4 does, it shouldnt install hdradio... the newest hdradio is always in the newest RideRunner installer package
    i would not use any dll supplied by anything other then the RideRunner package
    as for volume... 1st lower your input gain on the line in via mixer control
    i would avoide at all costs lowering the volume of the hdradio, but it can be done
    its in the documentation that no one reads!!! (settings.txt)
    hdvolume=0-90
    Sets default HD radio volume. Default is 75, range is from 0 to 90.
    in RR.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #1037
    MySQL Error
    Oct 2004
    NO, thats quite OEM, and no easy way to get one
    Fuba is a company that makes antennas for VW
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #1038
    Jul 2008
    West Virginia
    I don't know what I was thinking (or the lack there of).
  9. #1039
    Low Bitrate bigbuffs's Avatar
    Nov 2007
    I am in the processes of reinstalling all of my stuff do to a hdd failure and I can't get this working in rr. I'm using elite and when I start it up I get this message "sorry mjs gadgets hd radio control assembly is not registered" I'm not sure what is going on but the radio works fine with the standalone PCR program.
    Attached Files Attached Files
    [||||||----] - 60% Complete
  10. #1040
    MySQL Error
    Oct 2004
    try reinstalling RideRunner, using the newest installer, and if you just did, try installing .net framework!!!
    since its a new machine, alot of people forget to vistit windows update, and get .net
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 07:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 01:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 05:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 02:48 AM
