Thread: HD Radio Cables READY!
  1. #1241
    MySQL Error
    Oct 2004
    Quote Originally Posted by Superduck View Post
    Do tell? I just got my Directed unit ($25 shipped from eBay!) and ordered your cable. I'm wondering how I should go about running this and a mic. I was thinking about outputting the RCA's straight to the amp, perhaps with a Y-adapter, but if you've got something better, I'd love to hear about it.
    Could you PM me the info, perhaps?
    Also, in regards to my cheap Directed box, one caveat, it didn't come with ANY cables, just the box. The power plug looks a lot like a P4 connector, anyone know for sure if one will plug in? I can just pirate one off an old power supply. I've found the pinouts somewhere online for which ones are power and which are ground.
    Thanks in advance,
    Kris
    well.. i would connect it to a line in, not a mic in... mic ins are usually MONO
    if you dont have a line in, thats where my new product comes into play
    its just a simple usb audio device, im not 100% happy with it, but thats Texas Instruments fault
    but it would work fine for ya
    better in vista/win7, then in xp... in some aspects
    now that connector...
    its a mini-fit jr
    looking at it with wires exiting rear. clip on bottom
    http://www.molex.com/pdm_docs/sd/039012040_sd.pdf
    12
    34
    1 = 12v switched
    2 = empty
    3 = 12v constant
    4 = GND
    I have plenty of these connectors, i could make u up one
    1 & 3 can be tied together, and connected to 12v constant or 12v pc power(yellow on hd connect)
    since power is also trigged via rs232 connection
    pm me
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #1242
    Jul 2006
    Northern CA
    Quote Originally Posted by mitchjs View Post
    its a mini-fit jr
    12
    34
    1 = 12v switched
    2 = empty
    3 = 12v constant
    4 = GND
    pm me
    gogo mitch, thanks for fixing my diagram, i knew i had something backwards, but it's hidden away behind soldered wire and digging it up usually results in cuts on my hand because my car doesnt like me >.>
  3. #1243
    MySQL Error
    Oct 2004
    i hope, i got it right
    i think it so... im used to clip up... but offically molex says clip down
    clip up, wires exiting
    G C
    * A
    G = gnd
    C = constant
    * = open
    A = Accessory
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #1244
    Newbie MusicMonkey5555's Avatar
    Mar 2008
    Kirkland, Washington, United States
    I have Centrafuse 3 and it says that this hardware is supported, but I can't for the life of me figure out how to get it to work. Has anyone tested it out? Any tips? Also from the looks of it you can still get standard channels through this as well correct? (non-hd standard am/fm radio)
    Thanks in advance for any help.
    Note: I have the VISTEON HDZ300 installed VISTEON HDZ300 and a http://www.amazon.com/gp/product/B00...ef=oss_product running from it to the cable. Hoping the extension cable will work. Haven't messed with serial cables much so not to sure on how to test it either. I tried plugging the extension into the controller that comes with the VISTEON to just test the cable and unit, but nothing when I hit the power. This should work shouldn't it? Or is the cable missing some pins or are any wires flipped?
    2007 Ford Focus
    Project Page
    Software - Win7, Centrafuse, Firefox, MediaMonkey, Trillian
    Hardware - Intel X25-M 80GB SSD , VIA C7, Jetway J7F5M-VDE, Kingston 1GB RAM, Preassembled 2Din Frame w/7" Lilliput EBY701
    Planning: 85%
    Parts: 95%
    Install:75%
  5. #1245
    MySQL Error
    Oct 2004
    Quote Originally Posted by MusicMonkey5555 View Post
    hu?
    you did wire up power? yellow, red....& black wires
    i assume you have my interface cable?
    just get everything working with say HD PCR application
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #1246
    Variable Bitrate egeekial's Avatar
    May 2004
    Are you out of cables again? I'm getting "Product not found!" on your website.
  7. #1247
    MySQL Error
    Oct 2004
    yep all gone...
    im gonna make more... a buddy just secured a bunch of tunas
    and sucked em all up
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #1248
    Mar 2008
    So I got it working with the HD PCR application and the interface that comes with the HD radio, now I just need to figure out how to get it to work in Centrafuse 3.0.
    Has anyone got it working in Centrafuse and if so what are your settings.
    I am guessing the key setting is Device under settings > Advanced > am/fm Radio.
    2007 Ford Focus
    Project Page
    Planning: 85%
    Parts: 95%
    Install:75%
  9. #1249
    MySQL Error
    Oct 2004
    yes... and and chosing right audio line, which can be an issue in CF
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #1250
    Mar 2008
    So what device would I choose, I didn't seem to see one that made sense.
    2007 Ford Focus
    Project Page
    Planning: 85%
    Parts: 95%
    Install:75%
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
