Thread: HD Radio Cables READY!
  1. #1281
    MySQL Error
    Oct 2004
    turn off the radio? NEVER want to do that...
    its either active or inactive
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #1282
    Jul 2006
    new york
    Well then your software power button makes it inactive..that's what I wanted into centrafuse. Thanks Mitch forum replying software prumply.
  3. #1283
    MySQL Error
    Oct 2004
    no, that powers it off, and we dont want to do that in CF, it would ruin the user experience, switching from sources need to be instant
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #1284
    Jul 2009
    ok thiers alot of posts in this thread so i dont know if this was already covered and i missed it but i need help.
    i have had my car pc for about 7 months now with no real issues except the radio gets almost no stations. i have tried 2 different antennas and 2 different directed radios and a antenna amplifier. i do get some stations but only barely and only like 2. the main station i listen to i cant pick up. i can pick it up in my truck on the stocksystem almost a 100 miles away so i know the station has a strong signal. any one have any suggestions?.
    my setup is powered by m2 atx running xp. the radio is only about 8-10 inches from the pc which is mounted on a board right in next to the power antenna so the antenna cable is pretty short. with the antenna fully extended fullly i can get 1 station but its hit or miss. with it down i get nothing but static.
    i dont just suck at spelling i also suck at typing.
  5. #1285
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Quote Originally Posted by luna123black View Post
    I have basically the same problem. My Toyota has 2 antennas that provide diversity to the stock radio. I have one connected to my after-market Kenwood deck, the other to the Visteon module. Neither picks up as well as the stock radio. There is an amp which I have powered, and I've tried swapping the antennas but it didn't make much difference. I also tried one of those hot-rod "hidden" antennas but it was worthless.
    Nothing does a good job replacing a metal aerial sticking up from your car IMO. The lower version of my van does have a real metal antenna on the front fender, and I've considered drilling a hole and putting one there. I've also been thinking about getting one of those smaller antennas you see on many car roofs now, but to be honest I just don't care enough to go to all the trouble to find a good one, drill the roof, run the cabling, etc. It's just easier to stream a station over 3G if I really want to listen to it.
    If anyone has a suggestion though I'll check it out.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  6. #1286
    MySQL Error
    Oct 2004
    try it with out the pc being on, use the supplied ugly display...
    also... is the oem antenna amplified... you done mention what kind of truck
    but if it has an amplified antenna system, that has to have power...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #1287
    Jul 2009
    ok i took my xtra directed unit and hooked it up in my house useing the ugly display and one of the antennas i tried in the car. it worked fine just like it should. so im guessing my problem is my install could the radio be to close to the pc. it will be a pain in the *** but i could move it aslong as i can use a serial extension cable. moveing the pc at this point is not really a option with all the cables run and everything mounted.
  8. #1288
    MySQL Error
    Oct 2004
    yes!!!! THE PC AND its powersupply and RFI nightmares!!!!
    i would put tuner, where oem radio was... and do not extend antenna any
    and then extend the rs232 or make sure you get a wired straight 8 pin mini din extension
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #1289
    Jul 2006
    new york
    I have a Pac TR4 to connect to my antenna....any help as to which wire I need to tap into for the signal on the serial cable?
  10. #1290
    MySQL Error
    Oct 2004
    hu?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
