Thread: HD Radio Cables READY!
  1. #1291
    Jul 2006
    new york
    Quote Originally Posted by HiJackZX1 View Post
    HMMMMMMM. Sounds easy. Maybe hack into the pin on the serial port that sends the signal for the HD Radio to turn on. The use a device like a PAC TR-4. I use this with my amps. Basically it monitors pin 5 on my serial port and when AMP_CTRL turns on, it activates pin 5, then that activates the PAC TR-4, then you connect that to the antenna. Thing is, I dont know about power antennas or how they work. I simple low power sencing relay may also work in place of the PAC TR-4.
    Here which wire need to tap into...
  2. #1292
    MySQL Error
    Oct 2004
    thats not going to work... the radio is always on... IF done right, ie in RideRunner, and CF
    you need to raise your antenna when the radio is ACTIVE
    my 1st question is this a car with a raising and lowering power antenna? you dont seem them much anymore
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #1293
    Jul 2006
    new york
    How does I do that? Its a QX4 runs CF
  4. #1294
    MySQL Error
    Oct 2004
    well... not easy... u got a unused com port?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #1295
    Jul 2006
    new york
    No...I have extra usb
  6. #1296
    MySQL Error
    Oct 2004
    well... there is no simple solution then...
    i did a USB Relay plugin for CF, i cannot recommend the USB relay again
    because its design does not follow USB current consumption
    unless you are removing all power from the USB system at shutdown...
    there is another option of USB relay on ebay, but i of course dont know if its made right
    till i have one in my hand
    works, but cannot reccomend:
    http://cgi.ebay.com/USB-1-Relay-Cont...item19c023e0bf
    can make work, but unknown if designed right:
    http://cgi.ebay.com/USB-2-RELAY-CARD...item1c15f1da82
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #1297
    Oct 2010
    Boomzbox vs. Visteon & cable by Mitch
    My apologies if this has been covered already... but this is a looooong thread and I couldn't read it all three years of it!
    I'm looking for an HD radio solution. What's the best solution that is controllable from RR and/or CF? A Visteon with Mitch's cable ($115 amazon + $25 Mitch + $15 USB dongle= $165) or a Boomzbox from mp3store ($185 w/shipping)?
    Are they equal in terms of Frontend functionality? Boomzbox has the advantage of being USB, saving the hassle of a serial converter
    Tim
  8. #1298
    MySQL Error
    Oct 2004
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #1299
    MySQL Error
    Oct 2004
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #1300
    Oct 2009
    Has anyone found a good deal on a FTDI based usb-serial cable?
    This is what I've found...
    http://www.usbgear.com/computer_cabl...99%2C601%2C461
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
