Thread: HD Radio Cables READY!
  1. #1311
    Nov 2010
    I need desperate help with my Directed unit.
    I have tried everything to get my pc to control it with mitch's cables.
    the unit works fine and I get audio through my line on on my PC when I use the supplied interface module.
    I have just reformatted my PC with Win 7 Ult. 32bit. I made sure that the Usb/serial cable was the first one installed and set it to COM1. I cannot get the HD Radio PCR to find the directed.
    I have told it to look on COM 1 and still no luck.
    I have it wired:
    yellow = constant
    red = Ignition
    Black = ground
    I have heard to run the IGN off of the constant as well but I cannot afford to have a dead battery as a result.
    I do not Have an extra 12v to run the red line off of.
    Please help. It's the only thing not working on my new setup.
  2. #1312
    Jan 2003
    Quote Originally Posted by eyelobes View Post
    I have it wired:
    yellow = constant
    red = Ignition
    Black = ground
    If it works with the supplied interface module, your problem is not the power wires. The problem is probably the Serial-USB adapter. Either it's not compatible or the drivers aren't installed correctly.
  3. #1313
    MySQL Error
    Oct 2004
    usb->com port is prob it... cheap one dont work... if they dont support DTR line
    also.. u might want to consider red to constant, not ignition, if you do plan pc control of this device, and use hibernate or suspend, the bottom line is, the unit has to have power, when the PC has power, and ignition is NOT a good choice
    the power is controled via the rs232 cable...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #1314
    Nov 2010
    The adapter taht I am using is a Manhattan with prolific 2303. Windows sees it just fine and says that the device is working properly on COM 1.
    I can controll the unit from the supplied interface remote and unplug it, which leaves the audio going. As soon as I plug in your cable it turns off and can't get it to turn back on.
    What is a serial usb that you know will work in windows 7 that I can pick up locally?
  5. #1315
    Nov 2010
    I will rewire the HD radio if I know for a fact that it will not kill my battery. It is pretty easily done.
    I am using Prolofics latest driver instead of the one that comes with the cable. I am going to try the one off of Manhattan's site.
  6. #1316
    MySQL Error
    Oct 2004
    the cable controls the power... if the pc says off to the tuner, its off, and wont kill your battery...
    prolific should work fine, it might be the unit itself... say not supporting DTR
    i dont know...
    id assume it would work... but some of the really cheap ones dont (under $20)
    you can test, with bray's terminal
    open the comport, and click on the dtr... that should make the tuner click on/off
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #1317
    Nov 2010
    Ok, I tried the terminal trick and connected to ths port and clicked dtr....nothing. What adapter will work with win 7 for sure. Dont want to fiddle with this anymore. I just want it to work.
  8. #1318
    MySQL Error
    Oct 2004
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #1319
    MySQL Error
    Oct 2004
    im a bit shocked... that one dont work
    try on another PC, and dont touch the default comport it makes...
    ie com4
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #1320
    Nov 2010
    Yeah then second cable I had laying around ended up using the ftdi drivers but still didn't work, it was only an $8 cable though from sabrent.
    Here are the ones I'm using:
    http://www.manhattan-products.com/en...rial-converter
    http://sabrent.com/v2/usb-2-0-to-ser...er-1-ft-cable/
    I realize that they are both pretty cheap but I haven't got a lot of money left and this is the last snag in the pc. Ugh, it's just annoying.
    Thanks for all of your help Mitch, I know it is just me trying to cut corners because of cost. I will try it on my wife's netbook when I get home.
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
