Page 138 of 141 FirstFirst ... 3888128129130131132133134135136137138139140141 LastLast
Results 1,371 to 1,380 of 1408
Thread: HD Radio Cables READY!
  1. #1371
    MySQL Error
    Oct 2004
    i wouldnt tell you to connect it that way, if it would run down your battery... the control cable controls power!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #1372
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    All right, I'll admit it, it works fine connected to constant power... DANG IT LOL!!! Thanks!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  3. #1373
    Apr 2005
    Plano, TX
    Hey Mitch, another question. The station I usually listen to is sub-channel 2. My system hibernates on power off, and when I start the car up and it all resumes the radio goes to the same frequency but on sub-channel 1. Then I have to go back to the radio skin and select sub 2.
    When the radio starts up and I start to hear it, then after a second or two the HD kicks in, so maybe the command has just been sent way too early for the Visteon to process.
    Is there a way to repeat the command automatically or do you have any other ideas? Thanks!
  4. #1374
    MySQL Error
    Oct 2004
    thats how HD radio works... it tunes to the analog, and looks for digital signal... then blends in...
    it will always start on the analog
    if we told it to tune to an HD2, and hd didnt exist, you would get nothing...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #1375
    Apr 2005
    Plano, TX
    Exactly right, which is why I asked if there was a way to repeat the command?
    What I should have asked is if there's a way to have RR run a command after a delayed period of time from startup or resuming from hibernation?
  6. #1376
    MySQL Error
    Oct 2004
    well... im sure there is a way... for sure in a custom plugin, or a script
    nothing native comes to mind...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #1377
    Nov 2004
    St Louis
    You can write native RRCode to do it based on a variable, see some of my old startup RRCode using audiosource.
  8. #1378
    Apr 2005
    Plano, TX
    Thanks GizmoQ, I'll do some searching for that. I've also asked JohnWPB who is the master of skin magic and scripts LOL.
  9. #1379
    Constant Bitrate tibimakai's Avatar
    Feb 2005
    San Pedro, USA
    hi Mitch, I have your serial cable which it was working great until I pulled the cable and I found some broken cable inside the serial connector.
    It was the shield wire, which I have resoldered, but the HDPCR still can't find it. keep asking which comport to use?
    what could be the problem? do you have a diagram by any chance with the wireing?
    there are two wires which they look like are not connected, am I right?
    I hear the clicking of the radio.
  10. #1380
    Sep 2011
    Hi Mitch,
    i have your cable with the HD Direrected Radio running CF 3.6 and would like to ask if i can wire yellow and black directly to battery and red to an unused disk drive power cable from the pc' s PSU? Would this configuration be enough to remain the radio active until the hibernation process ends, so there is no problem when resuming?
    TIA,
    Paulo
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
