Page 17 of 139 FirstFirst ... 78910111213141516171819202122232425262767117 ... LastLast
Results 161 to 170 of 1381
Thread: HD Radio Cables READY!
  1. #161
    MySQL Error
    Oct 2004
    as for rfi, only way would be to dump the amp
    now rfi really shows up on AM as high pitched noise
    class D amps could have this, with their hight freq switched power supply
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #162
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Have you looked into RR and the tuner at all mitch?
  3. #163
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Finally...I get decent radio again.
    Thanks again mitch for all you hardwork on this.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  4. #164
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Anyone else having a problem with config overwriting your hd radio settings everytime you save an config change?
    I manually edit the rr.ini, but config overwrites as there is no option for HD radio in the config utility yet.....
    Only when I Make a change and save though Config..............
    *edit- nevermind, I was using an older version of config. Solved*
    Leonardo Da Vinci
  5. #165
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by JohnWPB View Post
    I am not sure how to fix it, but am pretty sure it is in RR"s code, and nothing to do with the plugin, DLL ect.
    RR needs to keep track if the radio is playing or not, and know that when going to the screen.
    It is especially annoying when I hear a song on the radio, and switch to the skin to see the title and such, and it tunes to another station!
    I agree and believe this is in the RR code also. I know my HQCT had a ini file in the hqct directory in RR to save presets. I have great functionality with this tuner and RR so far, can tune really good signal and sounds great with no noise (yes i did your ground mod mitch )
    Anyway I do think RR just needs some more coding to make this happen. It also seems that RR will lose communication with the tuner if I go 3 or more menus deep away from my HD skin. Only fix is to go to mp3 or vid, then back to HD which sets me back at 87.5.
    I know the software will catch up soon This is the newest tuner available to RR so I did not expect it to be perfected just yet. I am going to be releasing my new skin very soon with the note that HD is still in beta. Hopefully we can get some more heads working on this to get it solved.
  6. #166
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by greatwhite View Post
    get the most up to date version of rrconfig from bluezx3's thread. The older version doesnt have hdradio set as an option.
    Live mp3Car Facebook Chat
  7. #167
    MySQL Error
    Oct 2004
    did he remember to add the comport selection when u chose hd radio?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #168
    May 2007
    Quote Originally Posted by mitchjs View Post
    mitch
    Yup.
    It's all working now gents. My only issue I had was my INI files being re-written everytime I saved a Config. When I noticed there wasn't an hd radio selection in config it all clicked in what was wrong.
    I must say, it seems pretty good so far. I've got it runing in the basement, 3 feet below grade, without an antenna and it's pretty much as as good as the radio shark with an antenna (and a clear sight line to the tower) that I was running before. Can't wait to get this puppy hooked up to an antenna and see what it'll do in the car!
    Cheers
    Leonardo Da Vinci
  9. #169
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    HD Perfect
    I just finished the install of my HD Radio Tuner, and boy can I tell you.....this THING rocks. It sounds way better then my BOSE Radio in the Envoy. (My other Car).
    Here is a shot of it running in the car with all it's glory. The camera is crappy, I know.
    I have also attatched the skin file with the code (If someone want's to play with it.
    The SEL button cycles to the sub channels and when held down, it brings up the PRESET Menu.
    Attached Files Attached Files
  10. #170
    Jan 2007
    dundee, il
    just ordered my tuner on ebay, got it for $45 and just placed the order for the cable, i cant wait to get this working, radio is the only thing i miss about my old (regular) sound system. thanks for all the work everyone has put into getting this to work.
    david
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
