Page 18 of 139 FirstFirst ... 891011121314151617181920212223242526272868118 ... LastLast
Results 171 to 180 of 1381
Thread: HD Radio Cables READY!
  1. #171
    Mar 2007
    problems... helpppp
    ok i have 2 problems.. but first I have to thank Mitch for his cable.. quick shipping and great purchase.. the Visteon HD radio gets great reception even with the stock BMW antenna in the rear window.. Heck I bought another one for my home stereo, cant beat the price on ebay..
    ok heres my first problem.. I have a soundblaster pci card in my carpc which i have front and rear outputs, im using line in on the card for the visteon. When using mitch's software to control the visteon, the sound only outputs through the front speakers.. I cant seem to figure out why?? everything else that plays from the computer plays out on front and rear speakers.
    Next I cant seem to get roadrunner to control the radio.. from my search here there doesnt seem to be any guide for a software idiot like myself. I have the new version of roadrunner (downloaded the bin and put it in the roadrunner folder).
    would it be possible for one of you software guru's to make a step by step process of how to get roadrunner to control the visteon??
    Many thanks.. James
  2. #172
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    First of all, Mitch's cable does control the audio part of the tuner. You have two RCA outputs on the Tuner for your audio. If your LINE IN does not work correctly with the Card, I think it should, you can allways try the CD IN on the motherboard and see if it makes a difference.
    Software wise, if you downloaded the newest version of RR then you can see a subfolder in the RR Directory, called HD Radio. There are six files in it. Double Click the file called
    "runme1st". After that run RR Conifg.exe and under the RADIO settings select HD RADIO and the Audio Line you use for the Radio.
    Next, look in the RR.ini file under the RADIO part, there you find this.
    [Radio]
    radiomode=8 >tell RR to use HD RADIO
    allowallfreqs=false > Tuning of the Frequecy steps (88.5,88.6,88.7 and on)
    radioline=1 >wher the audio comes from
    userbds=false > for PTY info false for europe, true for USA
    hdradioport=1 >the com port you pluged mitch's cable in
    Now, when you click on RADIO in your skin, you should hear a click in the tuner and it should start playing.
    Look in your mixer and make sure you don't have anything muted that you need.
  3. #173
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Hmm, seems crosslakesales has raised their prices.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  4. #174
    Nov 2005
    I got mine from crosslakes for $61 USD on auction. The price will vary depending on who bids when.
  5. #175
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I paid a "little" bit more than you lucky guys....................just under 180 bucks cdn shipped to my door................
    I bought before the most recent seller showed up on ebay, still worth it for good radio.
    Leonardo Da Vinci
  6. #176
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by blk02si
    That should be fine, when the car is running it puts out 14.4 volts so the tuner has to have some built in regulator.
    Im still trying to figure out how to have roadrunner save a list with this tuner, and also to return to HD menu and save the station it was on. Right now any time I leave the HD menu and come back it is at 87.5 and I have to retune it.
    Quote Originally Posted by JohnWPB View Post
    I am not sure how to fix it, but am pretty sure it is in RR"s code, and nothing to do with the plugin, DLL ect.
    RR needs to keep track if the radio is playing or not, and know that when going to the screen.
    It is especially annoying when I hear a song on the radio, and switch to the skin to see the title and such, and it tunes to another station!
    This is not an RR Issue it is a user issue, sorry to say. You are more than likely in LOCAL mode when creating your playlist or tuning stations. Switch back to your main playlist by using creating a LOCAL button in your skin to toggle back and forth.
    THIS WILL SOLVE YOUR PROBLEM....
    New Age Garmin - Skin for RR
  7. #177
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Any of you guys using a the code for presets in RR working for the HD radio skin?
    Code:
    FMPRESET;PRESET1||SETVARBYCODE;FMP01;FREQUENCE||SAVETOSKIN;FMP01;$FMP01F$
    It's not changing the Frequency for me.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  8. #178
    MySQL Error
    Oct 2004
    Hey guys, just want to let anyone know who ordered my cable with in the last week
    I did run out, but good news, more are here this week
    i should have em out the door by thursday (12/20)
    Support was way more then i expected, i had NO idea how popular this would be
    thanks all again!
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  9. #179
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by ThunderStick View Post
    I will give this a try and see if it works. I was messing around with the local setting while bench testing and It didn't seem to matter but Ill try again. When I click local it just wipes the list again. Thunderstick what happens in your setup if you go to HD, set a few presets , go to your mp3 menu, then go back to the HD menu. DO your presets stick?
  10. #180
    Jan 2007
    dundee, il
    Quote Originally Posted by mitchjs View Post
    thanks all again!
    mitch
    good to hear, i just ordered one night before last.
    david
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
