Page 20 of 139 FirstFirst ... 10111213141516171819202122232425262728293070120 ... LastLast
Results 191 to 200 of 1381
Thread: HD Radio Cables READY!
  1. #191
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by Sal R. View Post
    Mine doesn't. It doesn't turn off ("click") until I switch media, like audio. I don't know how it would work with something like sat radio or tv, but the radio is on until I switch to audio.
    True, and this would be a more accurate description:
    Anytime I switch to media that requires audio output, the hd radio emmits it's "clicks". Any screen that does not require audio output does not shut the HD unit off.
    Cheers
    Leonardo Da Vinci
  2. #192
    Nov 2005
    still good news
    Thanks for the clarification.
  3. #193
    MySQL Error
    Oct 2004
    Iceman, I didnt write the RoadRunner part GUINO did...
    best ask him that...
    I wrote the .dll that talks to the tuner (lower level)
    i see no reason to turn it off, until the key is out
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #194
    Nov 2005
    Understood.
    Regardless, I prefer the way it works at the moment (based on users' testimony). [IE: Turns on when in Radio mode, turns off only if another media type is invoked.]
    As such, Ive posted this mod for controlling a power antenna:
    HD Radio Mod: Power Antenna Trigger
    Ice
  5. #195
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Mine is working awesome with my ford OEM antenna setup!
    I think I have nailed my presets not sticking to my embedded setup. I have the OS and RR running embedded (read only) on solid state media.
    This tuner is by far the best am/fm/hd solution out there hands down.
  6. #196
    Jul 2006
    ok ive got a question im hoping someone can answer for me before i jump on this purchase. i am using the kxproject drivers for my audigy sound card which use their own mixer as opposed to windows' mixer. what this means is that in RR (which interfaced with the windows mixer), i only have access to master, wave, and winamp volumes. i have no access to mic or line in volumes, nor do i have the ability to mute them from inside RR. so basically, in my case, those inputs would have to remain always on, and i would have to have some way of actually turning the radio transmission itself on/off instead of muting/unmuting its input. does the interface we are using support this, or does it only support muting and unmuting the radio? in other words, when you visit the radio screen, is it actually turning on the radio, or is the radio already on and we're just unmuting its input. please help! thanks.
  7. #197
    May 2007
    Quote Originally Posted by hari-bhari View Post
    Short answer:
    Yup.
    Running and audigy 4 with the KX drivers. No issues. All skin controlled. Just rememeberto unmute your "line in" in the KX control panel.
    Don't ask me how I know..........
    Leonardo Da Vinci
  8. #198
    Jul 2006
    yep, i am using the audigy zs that has slightly less functionality with the kx drivers than other cards, so i basically will have to leave it unmuted all the time unless i wanna open up the kx panel and do it each time i want to listen to radio which would be a PITA.
    just to doubly make sure, you do *not* have control of muting/unmiting your line in through the windows mixer or in RR, correct? the radio is actually turning off when not used? if not, ill be outta luck, lol.
    btw what model are u using?
  9. #199
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Can someone please explain HD subchannels? Poking around, I'm not quite sure what they are and what they do and how they relate to the labels and stuff...
    I'm talking about subchannel2 and subchannel count, etc...
    TIA!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  10. #200
    MySQL Error
    Oct 2004
    someone on ebay is got a ton of the visteon tuners
    under $50, with < $10 ship
    tons
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
