Page 22 of 141 FirstFirst ... 12131415161718192021222324252627282930313272122 ... LastLast
Results 211 to 220 of 1408
Thread: HD Radio Cables READY!
  1. #211
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Yup, "ant in". checked that right away.
    I'm leaning toward an antenna problem also...........
    Leonardo Da Vinci
  2. #212
    MySQL Error
    Oct 2004
    does the car have a "normal" antenna, or is it amplified?
    is there a 31" mast on your car?
    and i would ground the rca, it makes it sound so much better
    otherwise your sound card/pc cant get a good ground reference for the audio signal
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #213
    Constant Bitrate djchicago's Avatar
    Chicago Ill
    Well I just ordered a cable from you and ordered a HDR from ebay for 71.00 with shipping ( my first buy from ebay). I hope all goes well an I hope to have a review soon.
  4. #214
    May 2007
    Quote Originally Posted by mitchjs View Post
    The car has an in glass antenna with an amplifier but I haven't used it yet because it's got a smaller motorola plug than standard. The aftermarket antenna I've tried wasn't 31", quite a bit shorter actually. I'll check it out.
    I'l try a jumper form the ground to the rca, sort of makes sense when you explain it that way. I'm skeptical, but it's worth a try I guess..........
    Merry Xmas
    Leonardo Da Vinci
  5. #215
    MySQL Error
    Oct 2004
    it does havent to be 31" i just wanted you to be clear on what kind of antenna
    i think is 30.5" anyway...
    but you just complicated my question even more, what antenna you using in the car? the cars glass antenna?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #216
    May 2007
    mitch
    Nope. I'm using a "mast style" antenna I picked up at a local auto supply store for trials. Looks to be around 20-24 inches long.
    The car is equiped with an antenna incorporated into the rear window glass from the factory. However, I am NOT using that, just the mast style right now.
    Once I get it working properly, I will attempt to use "in glass" antenna if I can find an adapter..............
    Leonardo Da Vinci
  7. #217
    Mar 2007
    problems with audio
    well the radio is up and running with road runner, using the bmw skin.. it works flawlessly, tuner is GREAT, rds kicks ***, mitch's cable came quickly and works like a champ.... BUT, im still having the same problem where the sound is only coming out the front speakers, anything playing from the hard drive (mp3's, movies, gps) plays out all 4 speakers just fine and dandy.. I have a diamond 7.1 xtreme sound card, using 2 of the outputs for front and back speakers. tried using the line in and the mic in on the sound card to get 2 channel stereo.. no dice. I even tried inputting into the computers onboard sound.. mic and line in, still no dice..
    someone has to have had this problem???? im about to break something.. sigh.. maybe i should have sprung for the sound blaster card?? anyone else using a sound card the same way I am?? what sound card are you using?? ill go buy it weds..
    many thanks, james
  8. #218
    MySQL Error
    Oct 2004
    greatwhite, well, with a mast antenna as long as its grounded to the body well, should work great... does for me
    hadalgo, you know its technically only 2 channel audio...
    infact, mp3s and such is 2 channel audio, its most likey that winamp is set to mirror the front channels to the rear rear channels... i dont know for sure since im not a carpc person
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #219
    Nov 2005
    Got mine working very nicely!
    Im in Australia. Just letting other Aus people know that the FM sounds great. AM is still being worked on (USA uses 10Khz spacing and Aus uses 9Khz - so currently it can only tune to stations whose frequency is a factor of 10). So it cant tune to AM stations properly yet. I dont have mitch's cable, so im just using the LCD controller to tune for now. Sound is excellent though. Reception is much better than my Silabs so far. Will try it in a moving vehicle shortly.
    I hooked the +12V & ACC together onto the car's ACC line, rather than connect the +12v with the battery. This way the device is only on when the car is running, and I dont care if the unit forgets its presets, as that will be stored in RR's settings file anyway.
    Antenna extension mods also works pefectly .
    Ice
  10. #220
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Iceman_jkh View Post
    Ice
    once you get the cable i'm 80% sure you can fine tune thru rr.
    Live mp3Car Facebook Chat
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
