Page 26 of 141 FirstFirst ... 16171819202122232425262728293031323334353676126 ... LastLast
Results 251 to 260 of 1408
Thread: HD Radio Cables READY!
  1. #251
    MySQL Error
    Oct 2004
    GW, how about its a bad tuner?
    test it inside the house... course u need some sort of antenna
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #252
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Just got the tuner today. Will be ordering the cable in a few days. I do need to replace the inline fuse case, since it was broke......anyone else have this trouble?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  3. #253
    Nov 2005
    Quote Originally Posted by mitchjs View Post
    mitch
    And be careful that the 'inside' location isnt too well shielded from RF (ie: brick/steel walls or basement). Best would be outdoors (open sky/no mountain occlusion), but running of an AC powered PC using the +12v PC rail as power source. Use a know good normal FM radio as a signal reference I guess.
    Peace
    Ice
  4. #254
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    mitch
    I have considered this possibility, but since the solution is to buy another tuner, I'll just keep working at this one for a while.
    I resolved the low volume issues. It had someting to do with my kx driver. The line in showed "unmuted" but on a larf, I reinstalled the driver. When I muted and unmuted the line in, the peakers nearly blew my ears out. A bit of adjusting in the driver settings set everything fine volume wise. I still have poor reception, but I think I may end up chasing that to a grounding issue.
    My adapter for the in glass antenna came in today, and I tried it out. The reception is better than the mast antenna, so there may be an issue there. I may look at adjusting the radio to the antenna attenuation with what looks like the antenna tuner in the hd unit. It's a pot that is visable with the cover off, at least, that's what I think it is. I'm still looking into that.............
    Also, haven't gotten any AM stations yet. Not even "static-y" reception, just noise.
    Keep in mind though, there's no HD broadcasts here right now either.
    Quote Originally Posted by PontiacGA View Post
    Yup. Solder joints let go when I turned the unit over in my hands. A quick solder job later, better than new.
    Quote Originally Posted by Iceman_jkh View Post
    Peace
    Ice
    I'm to the point where I'll be testing in car only. If it can't be made to work in the car, it's gone....................
    Leonardo Da Vinci
  5. #255
    Mar 2006
    Pennsylvania
    Quote Originally Posted by greatwhite View Post
    Wish mine was that easy. The plastic housing was broke on mine. After doing a temp. tape job on it, tried it out in the house. Works great! Need to ground the RCA now to get rid of the slight buzzing noise.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  6. #256
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I just removed the inline fuse on mine since I hooked it to an OEM fused circuit.
    I was jamming out last night there were some great new years mixing going on in HD
    Let all your HD dreams come true in 2008!!!!!
  7. #257
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    question to those who have made there own hd radio skins....
    does anyone have the HDARTISTX/ HDTITLEX working? They dont ever seem to populate for me and i have HDARTIST1, HDARTIST2, HDTITLE1, HDTITLE2 all defined in my .skin.
    Live mp3Car Facebook Chat
  8. #258
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by Sonicxtacy02 View Post
    They work great in my skin
    New Age Garmin - Skin for RR
  9. #259
    Jul 2005
    Motorcity
    Blog Entries
    1
    They worked ok for mine but "RDSNAME" "RDSTEXT" seem to work better for me. They populate faster so I just used them. I don't display what is on the sub channel until I switch to it.
    Also has anyone noticed that any time there is a sub channel the "HDSUBCOUNT" label displays 3 even if there are only 2 streams. I have yet to find a HD stream with 3 sub channels yet anytime im in HD it says "3"
  10. #260
    Low Bitrate jumbodogs's Avatar
    May 2007
    CT
    I got my HD Radio yesterday and tried testing it out by connecting it to an old ATX power supply I had. I can't get it to fire up. I put the red and yellow to yellow wire on molex and black to black. I put my meter on the molex and it reads 11v and I also checked the HD radio power connector and its getting 11v going into the radio. I think ATX yellow puts out like 11.5v is this not enough power for the device? Anyways just wondering if I got a bad radio or not.
    JD
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
