Page 28 of 139 FirstFirst ... 18192021222324252627282930313233343536373878128 ... LastLast
Results 271 to 280 of 1381
Thread: HD Radio Cables READY!
  1. #271
    Aug 2006
    Columbus, OH
    Quote Originally Posted by mstaedt View Post
    I did a Google search on "HD radio carpc" and came across this thread (you guys should move this to the "Audio" forum where an mp3car.com nubie like me can find it instead of here in "Software->Front ends->Road Runner").
    I also ran across this: http://hd-radio.home.comcast.net/~hd-radio/. Has anybody used this software? It appears that the cable+SW+shipping is competitively priced with rush2112.net's package, but it looks like it has more functionality (i.e. automatically records mp3s, can be internet controlled, etc.). Plus, they offer a package that includes their $40 "everything" package AND a Visteon HD Zoom for a total of $75 + $12 shipping.
    I bought a Visteon off of ebay before Xmas and temporarily stuffed the whole thing into the glovebox of my mini-van just to try it out while I'm still developing my TruckPC. It is awesome! I might just buy another one so I don't have to take this one out of the mini-van when I need one for my truck.
    Thanks..
    Mark
    I ordered my cable 3 days ago from Mitch as well. Besides I don't like the postings from the Mechanic that owns that site that you ref to. Now I'm even happier that I ordered from Mitch since the other cable is not compatible with RR.
    Mitch: The HD Radio app from your site once I lauch it shows the "About HDRadio" window and this does not dissapear until I click on it. Will this interfere with RR once I have everything connected? OR does RR has its own HDRadio plugin that does not require this app?
    Thanks.
    Michael K
  2. #272
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    It was most likely started here since it's native to roadrunner, as the description on his website says...
    NATIVE Road Runner Support -
    Mitch, I was going to order the cable, but I'm curious to know what the $1.44 is for if the shipping is free?
    EDIT: NM. Must be sales tax. :P
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  3. #273
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    just recieve it today $40 shipped order cable soon
  4. #274
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    where do I begin...
    Downloaded Blue ZX3 config file RR is all upto date...(all under c:\program files...)
    when I click on runme1st.cmd I get and error:
    "The app failed to initialize proerly (0xc0000135) click OK to terminate"
    I'm lost and have the car running for about 45min now trying to get this thing to work!
    ----EDIT----
    Does it matter that I'm using Tiny XP in the car?....The reason I ask, I tried and it worked with another PC using XP Pro???
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
  5. #275
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Since this seems to be the most active Visteon thread overall... I wanted to ask for some help.
    I installed my radio this morning... working fairly well so far. However... my reception is not consistent at ALL. I live in the Dallas metroplex so I wasn't too worried about signal strength (pretty sure I can eliminate that variable).
    Here are some observations:
    I can add noise to the signal by moving my antenna cable around. Some spots seem to get better reception. Does having my PC installed in my dash add to much interference?
    Also, I noticed I could add noise by "shaking" the power cables, which by the way are LONG. I'm thinking about just cutting them down a ton because it almost seems to be acting as an antenna.
    Anyways, did anyone have any interference problems, and if so what suggestions would you have to solving them. I grounded the RCA, but that's the only mod so far. I have also tried placing the tuner itself far from the front of the car. Anddd.... it will tune to HD channels, but just as other stations the signal won't remain strong for very long and it will drop frequently.
    Some info about my install:
    Constant 12v to distribution block connected directly to battery. Switched 12v from PC PSU 12v rail. Ground to ground distribution block..
    Using control faceplate, cable is on the way
    I'm driving an '02 explorer, mast antenna
    Arggg, help!
  6. #276
    MySQL Error
    Oct 2004
    UM Fan, .net 2.0 framework... install that!!
    utd09bry, where are u moving the antenna wire, at the connector going into the tuner?
    2002 car is OLD(i know its only 6 years old)... now ur not as exposed to weather as i am, but i would consider replacing the ENTIRE antenna... AND ONLY USE OEM parts!!!
    u might not have to replace the whip, just the base, which has the cable
    (its not an easy job too)
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #277
    Sep 2007
    Dallas,TX
    Basically, while it is plugged in, if I jiggle the antenna lead as a whole, the reception changes. The connection is secure, it is the wire that seems to be picking up the interference.
    I think I am going to try to hook the tuner up to my head unit without the PC on and see if there is any interference. That way I can test to see if it is the screen or PC... will try in the morning
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by mitchjs View Post
    mitch
    Thanks, I'll try it this morning...after coffee
    Crazy Miami Drivers
    Old installation
    New Install!!!
    [/SIZE]
  9. #279
    Mar 2006
    Pennsylvania
    Wow. If a 2002 is old, my 93 Grand Am must be prehistoric.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  10. #280
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by PontiacGA View Post
    In terms of technology advancement, its a dinosaur
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
