Page 30 of 141 FirstFirst ... 20212223242526272829303132333435363738394080130 ... LastLast
Results 291 to 300 of 1408
Thread: HD Radio Cables READY!
  1. #291
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Mithc just suggested what I would have.
    Install the .net stuff, install his utility and see if it works. If it doesn't, you've got a line muted somewhere or and install problem, not RR or a skin issue.................
    Leonardo Da Vinci
  2. #292
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by mitchjs View Post
    i know i said this before, test everything with my application HD Radio PCR
    also, anyone thinking about getting a cable, only got 2 left!!! more will be here, but not for about a week!!
    mitch
    I ran down to the car during commercial break (and miss a TD score)
    Mitch, I installed your program and it work perfect...AM sounds sooooo sweet!!!!
    As I thought, it's my install....
    Later tonight or tomorrow, I'll post my ini file...
    On a side note for the guy with HD Radio working...what skin are you guys using?
    Thanks Mitch
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
  3. #293
    May 2007
    Quote Originally Posted by UM_Fan View Post
    Thanks Mitch
    Void 3.2
    Working but chasing down reception issues (not related to skin or rr, probably my install).
    Few points:
    .net (but you have this already)
    Make sure you have the newest void 3.2 download (if that's what you're using)
    Run the files in the HDradio folder (ie runmefirst, dll file, etc)
    RR.ini settings as described in thread (bluezx3's config utility makes this easy)
    Make sure your defined port is actually what your using in RR
    Good luck.
    Leonardo Da Vinci
  4. #294
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Thought I would share some results..
    My antenna appears to be just fine (even if my car IS a "dinosaur" :-p )
    With my computer OFF, the tuner gets HD in no time, holds the signal, as well as tunes to more stations than before.
    As soon as I turn on the PC, BAM, signal dies.
    I unhooked my screen, and same result.... so it must be the PC.
    I'm not sure what to do besides relocate the PC itself considering it is mounted up under the passenger dash right where the antenna lead comes in.
    So just FYI... anyone having reception issues should try that test and take the PC into consideration... it does make a difference!
    EDIT: By the way... when I was testing, I simply looked at the controller screen... I didn't re-wire audio so I could hear the difference. The time to lock onto the HD signal as well as the signal strength shown on the controller screen was proof enough.
  5. #295
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by utd09bry View Post
    appears you're having the same issues i am. I wish i knew what i could cover the pc with to prevent the interference from happening!
    Live mp3Car Facebook Chat
  6. #296
    Aug 2006
    Columbus, OH
    I'm having a similar situation like UM_Fan. I tested the Visteon HD Radio with Mitch application, it works fine. Then I start RR with BMV2 skin, when I click on the Radio button it delays like 5 seconds and then it sounds the inside relay 2 times separated by 1 seconds. Looks like it turns on and then off by itself. I ran the batch file runme1st.cmd and it completed successfully. I have .NET installed.
    My rr.ini is as follows:
    [Radio]
    radiomode=8
    allowallfreqs=false
    radioline=8
    userbds=false
    [Extra's]
    HDRadioport=9
    By the way I have to use a USB to serial converter (its on com9) because Mitch app did not wanted to work with the radio using built in serial com1 port.
  7. #297
    MySQL Error
    Oct 2004
    jarepa... maybe OLD version of RR
    a very very early testing .dll snuck out with a release of RR
    get the NEWEST RR
    and snag the .dll from the new rr's HD Radio dir
    or pm me for it
    im still waiting on someone to report back on the dll
    test... oh well ill just post it
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #298
    MySQL Error
    Oct 2004
    Updated DLL V1.1.0.1 built on 12/26/2007
    (not really)
    but everyone switch to this...
    just unzip to hdradio directory in RR directory
    and for kicks re run "runme1st.cmd"
    * changed Signal Strength Event (only events if signal change)
    * changed the rate of the signal strength polling
    mitch
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #299
    Aug 2006
    Columbus, OH
    Mitch,
    You are THE MAN!!
    It works perfect with the update you made. Now it works with my built in serial port and with the USB-->serial converter as well. I also tested with BMV2 and Digital FX2.5 skins, both good.
    Thank you for your great support.
    Michael
  10. #300
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    Hey Mitch,
    I hope this isn't too far off topic...
    This statement on your web page, "Includes FREE Software.
    Controll Class available for FREE for Devlopers..." Does this mean that API messages (or .net? or ???) are available to be used by other programs? I am building my own sort of "front end" on a program I use at work called LabView. I have been able to talk to Google Earth and a Garmon GPS receiver so far as well as perform various Windows commands from LabView. I would like to be able to do my own programming with your cable and my Visteon Zoom.
    I've downloaded your software to try and tinker, but it doesn't do much yet because I don't have a radio hooked to it.
    Where can I find the afore mentioned "control class?"
    Thanks...
    Mark
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
