Page 31 of 141 FirstFirst ... 21222324252627282930313233343536373839404181131 ... LastLast
Results 301 to 310 of 1408
Thread: HD Radio Cables READY!
  1. #301
    MySQL Error
    Oct 2004
    yea... its off topic.. thats a PM thing...
    a .NET/com object is avail... basicly its in the .zip file i just posted
    i do have a .xml file which is vs intelisense stuff
    (VERY handy)
    and i can provide source code to HD Radio PCR, which will show you real usage
    drop me a note on my forum...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #302
    Aug 2006
    Columbus, OH
    Mitch,
    I know this has been asked before here but is there any better way to change from FM to AM other than having to insert the frequency numbers manually? Are there any commands that I can include on the exectbl.ini or my skin that will make this happen?
    If not I'm planning to better embed your app into my skin, I even think it works better, but I still have the issue that your app only works with my USB->serial adapter and not straight from built in serial port (however RR works fine with my built in serial after the file you just posted recently). I wonder if you have an updated version of your HDRadio app.
    Thanks,
    Michael
  3. #303
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    Quote Originally Posted by mitchjs View Post
    Updated DLL V1.1.0.1 built on 12/26/2007
    (not really)
    but everyone switch to this...
    just unzip to hdradio directory in RR directory
    and for kicks re run "runme1st.cmd"
    * changed Signal Strength Event (only events if signal change)
    * changed the rate of the signal strength polling
    mitch
    Mitch
    Man I gotta thank you With the new DL it worked like a charm...
    Having AM and FM now after 2 year...how sweet it is!!!! I love you bro!!!!
    At this point I don't know why anyone would fool around with anything else.
    Now, we need are the skinner to start adding HDRadio to there files.
    I love all the hard work skinner like CdRsKuLL, MGD, liquid_smoke and other have done...
    But I'm running Via M10K and running a flash skin almost bring my PC to it's knees.
    Guess I have an excuse to upgrade!!!
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
  4. #304
    MySQL Error
    Oct 2004
    jarepa, the latest version of hdradiopcr is on my site
    if rr works with native serial port the hdradiopcr should...
    they both using same .dll!!
    the am/fm is all in the implementation of RR
    the tuner tunes to frequencies.. in my app, i just keep track of the last FM or last am freq when u change bands
    its all up to the programmer
    i bet with the powerfull skin commands a band button can be made
    using variables
    (remember i dont got carpc, im just here supporting you all!! and i thank you guys for the over welming take to this... i didnt think it would be this popular)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #305
    Nov 2006
    Can anyone who is using a serial to usb adapter with Mitch's cable let me know which brand/model you are using?
    With the one I'm using, it is preventing Roadrunner from writing resume.ini when I shut down. When I use the Mitch's cable into the computer's serial port, everything works fine. But I'd like to use it into my USB hub due to the location of my hardware. And with my adapter if I close RR before shutting down, it writes resume.ini. The adapter I'm using lists ftdi driver in the device manager, but I'm still having the problem. I'm guessing it doesn't support suspend as noted in the first post of this thread by Mitch.
    Any suggestion for a reliable adapter would be appreciated.
    jsoldi
  6. #306
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    is there a message or a function that rr can call to your .dll that changes the band? If so this would be pretty easy to implement into the "BAND" command rr already has.
    Live mp3Car Facebook Chat
  7. #307
    MySQL Error
    Oct 2004
    jsold, the ftdi's ones do!
    make sure you're using their newest drivers 2.0.24
    also... i assume that when you go into suspend, the comport is closed?
    maybe thats a issue
    sonicxtacy02, it doesnt work that way... you have to code band yourself
    (or have it some function precoded in RR, guino u around?)
    basicly
    if u on FM, save the LAST_FM_FREQ, then tune to the LAST_AM_FREQ, then to switch back, save LAST_AM_FREQ, and tune to LAST_FM_FREQ
    1st time in, LAST_FM_FREQ and LAST_AM_FREQ, should be lowest tuneable freqs on band, ie am 530
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #308
    Aug 2006
    Columbus, OH
    Quote Originally Posted by jsoldi View Post
    jsoldi
    I got mine off Ebay a year ago and still works fine. I have used it for my laptop that does not have serial port since I need to connect to many Cisco routers console via RS-232. I have now tested it with HDRadio and works perfect. The ideal USB-->Serial converters are the ones that support the prolific driver. If you like to check on Ebay auction # 310013871776 that's the same I have.
    Please note that I am not associated in any way to that Ebay seller, just use it as a reference.
    Michael.
  9. #309
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    i know i said this before, test everything with my application HD Radio PCR
    also, anyone thinking about getting a cable, only got 2 left!!! more will be here, but not for about a week!!
    mitch
    Can I order a cable without creating an account on your site?
    You can pm me for my paypal email to send an invoice/bill to paypal. I hope to get one of the last 2 before I have to wait .
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  10. #310
    MySQL Error
    Oct 2004
    matrixPC
    if u really dont want an account on my site, why i dont know.. but how about you pming me and giving me your paypal email...
    and only 1 left, more in about 10 days...
    (not to mention im going away for 7 days)
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
