Page 34 of 141 FirstFirst ... 24252627282930313233343536373839404142434484134 ... LastLast
Results 331 to 340 of 1408
Thread: HD Radio Cables READY!
  1. #331
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Quote Originally Posted by MatrixPC View Post
    Nah, I mess up the tracking number for the cable and the receiver. I got the receiver today instead of the cable, but it will be here either tomorrow or next day.
    Time for me to test the receiver in the car first before messing with the cable and PC.
    Heh. My cable orders still in processing.
    I tried my HD in the house with a spare car ant. Works great, but get a slight buzz from the speakers. Gonna try the grounding thing.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  2. #332
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    just for the record... i applied the grounding fix to my rca's before i ever tested the unit out. then, i ran into my ridiculous interference issues and in turn removed that connection.
    then i fixed the interference problem...
    for some reason, i cannot tell any noticeable difference between the grounding fix and without (i.e. im really not getting any extra noise)
    didn't know if anyone else might have had the same experience. how noticeable was the noise anyways?
    EDIT: I only removed the "grounding fix" among other things while I was trying to solve my interference problems. It did not actually solve the interference... just for clarification
  3. #333
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by utd09bry View Post
    uh... que????
    so you removed the rca ground.. and that did NOT fix your interference? If that didnt what did?
    Live mp3Car Facebook Chat
  4. #334
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by DaveDog View Post
    John,
    currently no, the serial cable plugs into the port you would plug the display into. I suppose a person could make a Y cable with some sort of switch to cut out the electronics in Mitch's serial cable. I don't really know. If anyone, Mitch would have the answer.
    I'm trying to do a Y cable as well, but my intention is a little different than yours. The Y "adapter" I'm going to make is just for switching the controller/carpc and audio source so that I can still listen/control the HD receiver while the carPC is NOT on.
    Quote Originally Posted by JohnWPB
    It would probably require some sort of switch, like a KVM switch for monitor, keyboard mouse kinda thing. I am sure if they were simply spliced, they would interfere with each other, or possibly even short something out!
    The cheap way, and probably a lot of work, would be to use 8 micro relays, one for each wire. When the power was applied to the relays, the computer would be connected, when relays were powered off, the external screen would be connected kinda thing.
    This is exactly what I'm doing. I have manual KVM switch laying around you know , but I better off getting some relays .
    Quote Originally Posted by mitchjs View Post
    you would have to electrically "merge" the RS232 signals
    remember rs232 has a negative swing
    basicly u have TX from the pc, and TX from the display, both need to go to RX on the tuner
    my 1st thought would be to bring em to ttl
    course there could be collisions...and then the message would be lost
    u could buffer the data... course now u got a microcontroller, and ram involed
    u could also use ur pc... one comport the tuner, the other the controller
    and pass data...
    now u got to code
    mitch
    Do you think using just relays or manual switch to switch the controller (carPC and display controller) causing problem like "signal collisions"? I'm not interest in using carPC and the display controller at the same time, but either or.
    This is how the cable look like with wire-by-wire split/connect.
    Code:
                                                 / Female DIN to Display controller
    Male DIN to reveiver -> Relay pack switch
                                                 \ Female DIN to CarPC (Mitch cable)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #335
    Sep 2007
    Dallas,TX
    Quote Originally Posted by Sonicxtacy02 View Post
    uh... que????
    Heh... well let's just say I changed a million things.
    I experimented with ferrite split beads, torroids, sealing up the case better, etc.
    I finally got something that seemed to work... which was a combination of: having the pc case as sealed as i could get it, putting ferrite torroids on the 12v constant and 12v switched lines as close to the psu connection as possible, placing a "antenna noise eliminator" that i got at Fry's inline with the antenna connection, AND putting ferrite split beads on mitch's cable because i was then getting interference across the serial cable.
    it was sick. but it seems to work.
    by the way, the "antenna noise eliminator" was nothing more than a black box housing an LC circuit in parallel with the +/- antenna connection...
    my only point about the RCA grounding was that i couldn't tell a difference with/without it after i had my radio working..
  6. #336
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    My tuner is ground referenced to my carPC chassis, which all my PCBs are grounded to and I have no noise issues with a straight forward simple install.
    Mitchjs, Let me know when you have more cables available, I am going to order another HD tuner for testing/developing on the desktop, its much easier than software programming on a 7" screen
  7. #337
    Oct 2004
    NY
    yeah, I'd like to know when the cables are available again too, a little late to this party, but sweet stuff here
  8. #338
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    Hey mitch, I noticed you took the HD radio cables off your site, but I ordered a cable on Friday.. is mine still coming through? No rush... just excited to finally have radio again.
  9. #339
    Dec 2007
    DC Metro area
    FYI, all HD cables are gone!, a couple people order after they where sold out...
    now, i expect more hopfully on thursday(ish) they will ship as soon as I assemble and test
    thanks
    mitch
    Ahh, this must also apply to me.. please disregard my previous post. Thanks in advance for the cable!
  10. #340
    MySQL Error
    Oct 2004
    i will fix site... im home on friday for a few hours, then off to disney world
    (im stuck now in a hotel with deathly slow internet, in dallas tx)
    i will assemble, and ship what ever is paid for by the time i get home
    i will fix the site to take some more orders
    ill try to catch up on any questions too
    again thanks for the overwhelming support, im glad to provide the solution for radio in the car for yas!
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
