Page 38 of 141 FirstFirst ... 28293031323334353637383940414243444546474888138 ... LastLast
Results 371 to 380 of 1408
Thread: HD Radio Cables READY!
  1. #371
    Aug 2006
    Columbus, OH
    Quote Originally Posted by landreww View Post
    Mitch, Just got your cable. HD)Radio works with 12v power supply and faceplate. When connected to notebook via USB to RS232 converter (using Huge Pine driver) the relay does not trip when using your software. I put on a serial port monitor and here is the output:
    Port opened by process "HDRadioPCR.exe" (PID: 2368)
    Port Closed
    your program then says that it could not locate a radio on a Com port.
    Do you (or anyone else) think that I need to set the com port for a specific speed or other setting? As an alternative, does anyone have a specific converter and driver combination that has proven to work?
    Possibly a defective cable (transistor)?
    Thanks in advance.
    That's because the quality of your USB--> Serial converter. I personally have to different models that use the same driver, with the cheap one doesn't work with the more expensive does. If you read some posts back on this same thread you will find I post I made with ref to the version that I have working that costs $8.99
    Michael
  2. #372
    Jan 2008
    Jarepa,
    I loaded HD Radio PCR application on a Windows 2000 CPU that has a serial port and the direct connection worked.
    Obviously the hardware handshake is not happening to raise the level of the signal line. I will order the cable you referenced in your earlier post. It lists the following:
    Supports automatic handshake mode.
    Supports Remote wakeup and power management.
    The one I have only lists the Remote wakeup and management, not the automatic handshake.
    Thanks for the advice.
  3. #373
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Unfriendly USB adapters, man I thought that a handshake should be automatic anyway....
    New Age Garmin - Skin for RR
  4. #374
    MySQL Error
    Oct 2004
    my 2cents on the ground, i found with out it my audio input couldnt get a good reference to the signal...and grounding the rcas got rid of a turn on thump(cap in the tuners output stage)
    i would consider grounding it, then using HQ isolation transformers (NOT A PAC GLI) the ones from davidnavone
    but it looks like its different for everyone... so..
    the object is to get HQ sound with no noise
    mitch
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #375
    Mar 2007
    HELP! I have the tuner working with the standalone HD Radio software on mitchjs's site. I have tried every RR radio skin I can find and none of them work at all (Thundersticks, MGDs, the LSX Void one, and the default non-HD ones in fresh installs of most of the current popular skins).
    I have downloaded the latest RR, downloaded the latest RRConfig, set the radio setting to HD in the config, ran the runme1st.cmd file in the HDRadio sub-dir, and even added "X,HDRadio\HDRadioComm" to the top of menu.skin. Still no luck. What am I missing here?
  6. #376
    MySQL Error
    Oct 2004
    newb77, its in the shrink tubing
    as far a i know, RRConfig HDRadio is incomplete...
    you need two lines
    [Radio]
    radiomode=8
    hdradioport=2
    course the port is you're comport
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #377
    Mar 2007
    Awesome. I had no hdradioport. Everything is workin great now. Thanks.
  8. #378
    Low Bitrate jumbodogs's Avatar
    May 2007
    CT
    Ok got my HD Radio other and hooked up in the car. Radio sounds and works great with the supplied LCD but when I hook up to computer I can't get it to turn on. I installed mitch's radio software but it can't locate the radio. Thanks for any help on this.
  9. #379
    May 2007
    CT
    Ok got it working with Mitch's software. I tried searching for new hardware which locked up my computer and I also screwed the cable in better and after restart the software found it. Don't think it was the cable being loose only because I could hear it click when computer was starting up before but either way it works and HD radio is great. Thanks for the cable Mitch.
  10. #380
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    Got mine in the mail yesterday and its working perfect with my Directed ebay special. Thanks for the fast service.
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
