Page 39 of 141 FirstFirst ... 29303132333435363738394041424344454647484989139 ... LastLast
Results 381 to 390 of 1408
Thread: HD Radio Cables READY!
  1. #381
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    Quote Originally Posted by KCarPC75 View Post
    I see where the problem resides.
    The radio station actually shows 6 sub channels but only 3 have content: HD-1, HD-2 and HD-4. If you try to tune to one of the Sub Channels with no content, the HD Radio hangs. If you select HD-4 by using HDSUB;4 it changes no problem. If you try to cycle from HD-1 through HD-6 it will hang when it hits HD-3.
    I just ran into the same problem. There is one station here that has 3 HD channels (according to the Visteon display, they are HD1, HD2, and HD3). RR shows that there are 3 HD channels available for about a second, then it tells me there are 7.
    Did you just run a trial and error to figure out that yours are 1, 2, and 4? I haven't identified the 3rd channel yet, but my RR stops responding just like yours when I try to hit HD3.
    EDIT: OK, I just determined that this station also uses HD1, HD2, and HD4. Where do you live KcarPC75? Maybe it's the same station - 88.5 in Greensboro, NC? Maybe NO station uses HD3. Anybody else run into this??
    Thanks...
    Mark
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
  2. #382
    Dec 2007
    Quote Originally Posted by mstaedt View Post
    Does anybody know how to write some sort of error handler to get around this?
    Thanks...
    Mark
    What I did was I took HDARTISTX and HDTITLEX and added 1-6 to my HD Radio screen to see which one was displaying info. I decided to just create buttons for the sub channels so I could run the HDSUB;X commnd to change the channel. If you use the code that just cycles through the sub channels from 1-6 it will hang.
    Also, you can hook up the visteon display and it should show you which sub channels have been detected.
    I'm guessing the visteon head unit just scans each sub channel to see if it has active content and only gives you them as options.
  3. #383
    Dec 2007
    Unfortunately, since this is an NPR station, there is no Artist and Song info. I only figured out that there were more than 2 HD channels when RR froze and I remembered (and luckily FOUND) your post.
    I guess it's no big deal for now since there is only 1 station in my area with more than 2 HD channels. But if anybody else adds additional channels and they don't use the same numbering convention, it may get complicated.
    Thanks...
    Mark
  4. #384
    MySQL Error
    Oct 2004
    nothing in my area is Hd3, when / if it happens... we'll explore
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #385
    MySQL Error
    Oct 2004
    hey we moved
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #386
    Low Bitrate jumbodogs's Avatar
    May 2007
    CT
    I am having same problem as before ... I can use the LCD to get the HD radio to work but Mitchjs software can't find the radio. I had to reinstall xp this weekend on the pc and now I can't get it to turn on.
  7. #387
    MySQL Error
    Oct 2004
    Comport problem, most likely
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #388
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Got my cable today. Thanks Mitch. I will have the radio Monday or Tuesday and then I will start fiddling with it immediately. I am going to integrate it directly into my own front end using the dll. The front end I am writing will be in .NET
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  9. #389
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Got mine...awesome job Mitch.
    One problem (no, I didn't read all 388 posts) If I use the radio, then go back to music...I click to go to the next song...no next song starts. The same song continues to play
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  10. #390
    MySQL Error
    Oct 2004
    muldrick, sounds like a RR issue, i think we need a new RR HD Radio Thread
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
