Page 40 of 141 FirstFirst ... 30313233343536373839404142434445464748495090140 ... LastLast
Results 391 to 400 of 1408
Thread: HD Radio Cables READY!
  1. #391
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    I struggled with intermittant HD radio working in RR - but it worked 100% of the time in the external software.
    Solution: 1) Make sure the com port is correct in rr.ini
    2) Make sure you're running RoadRunner.exe, and NOT rr.exe. All of my shortcuts were to rr.exe by default, but HD Radio only worked correctly with RoadRunner.exe.
    Works great now, thanks for the great cable Mitch!
  2. #392
    Dec 2007
    Mountain View, CA
    Has anybody had any issues with absolutely no radio reception? I have the Visteon HDZoom box and trying to bench test currently running the RCA's into a receiver. I can get the radio to power up and everything seems to work, except absolute no reception AM or FM. When I scan it runs through all channels. I do get a bit of static on all FM channels.
    Any suggestions? I'm going to try to return this, hopefully my ebay seller will allow it.
  3. #393
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Dude your unit is fine, just need an antenna to get signals.
  4. #394
    Dec 2007
    Mountain View, CA
    I plugged in one of the antenna adapters supplied with the unit. Granted it wasn't into the vehicle, but shouldn't you be able to get some sort of signal? I couldn't even get crappy FM or AM.
    Do you guys use an actual antenna when bench testing or something more then just a piece of wire? Just curious because it seems like many people here on forum were able to pull a signal when the unit wasn't connected to car antenna.
    Thanks.
  5. #395
    MySQL Error
    Oct 2004
    i use a REAL antenna...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  6. #396
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    I have successfully bench tested with nothing more than a 4" piece of insulated wire. Both ends stripped (maybe 1/4"). Shoved one end into the antenna input (make sure it makes it all the way into the center... the outer contact is a shield/ground.)
    I've picked up HD over a 4" wire. It doesn't take much...
  7. #397
    Jul 2005
    Motorcity
    Blog Entries
    1
    Using in it the house also yielded less desirable results than in the car. My house was like a HD Bermuda triangle. It work work great say near a window, but move 4 feet away and I would get nothing, much like your describing. I really did not hear the real output of this unit until it was in my car hooked up direct to my OEM antenna.
  8. #398
    Dec 2007
    Mountain View, CA
    Cool thanks. I just wasn't sure if i wanted to go through the hassle of pulling everything only to find out I had a bad unit. But I will definitely give it a try with car radio.
  9. #399
    Jan 2003
    I'm also having reception problems in car. I have an Acura TL which has it's antenna built into the rear windows. The stock HU picks up clear signal...however when I got my Pioneer 9800bt HU, I was getting static on some stations. With the Visteon, I'm only getting HD on a few stations. I live in So. Cal. Orange County where I the signal to be strong.
    Problem
    1) Stock Antenna is not sensitive enough, or is not designed for HD radio or
    2) Signal in Orange County, CA is weak
  10. #400
    Jul 2005
    Motorcity
    Blog Entries
    1
    Most likely the antenna type. The HD tuners seem very particular to mast style antennas.
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
