I made a cable to go from my hd radio to cd in..............my motherboard doesnt have cd in....when did they start doing this?!?!?! any idea of how i can fix this problem?
btw i have a via vb7001.
Jarrod
Printable View
Jarrod
As Professor Hubert J. Farnsworth would say, "GOOD NEWS EVERYONE"
I got tracking on the boards... assuming they are inside they box!
they are here tomorrow (wednesday 2/27) morning...
im gonna take off from DAY job (cause i love you guys) and solder and test
and ship!!! should get anything paid for already out by thursday!
thanks everyone for their patience
krnpimpsta, thanks for the response!!
Mitch
awesome news mitch....looking forward to my cable.....on another note, what is the deal with my motherboard? i dont have a cd in plug on my motherboard(via vb7001). but i have a adjustment in my volume for cd player volume????
ok well did a lil searching and found this http://www.intel.com/support/motherb.../CS-014753.htm so what might be my other options?
Question, can RoadRunner play audio accross devices?
wait... RR uses winamp and the winamp LINE in plugin of somesort right?
so say u are using a onboard audio system... that the speakers are connected to
and plug in say... USB Audio Input device...
would you be able to "capture/monitor" the audio from that device, and play it though the speakers connected on the onboard audio system
i hope you understand the question
windows doesnt do this natively
mitch
well WHAT usb audio device......?....anyway i did make a cord tonight to go straight into the pin header on the mobo for FRONT mic input. my rear mic is used as center/lfe. just messes things up if i decided to mess with voice recognition....o well...gotta have radio! thanks guys
Jarrod
Ok guys, i know you have heard this a million times but i can't get HD radio going in RR. I have it working with mitch's program, but not in RR. I have changed to HD skins, did the dll update in the hd folder, edited the config with many different options, updated my skin and rr. Please, i have been working on this for months, what else can i do?
You're most likely missing a setting in rr.ini
you need at minimum:
I also have these settings in mine:Code:radiomode=8
hdradioport=1 (or whatever port you are using)
Make sure your port settings are right and your GPS software is not stealing your port assignment.Code:allowallfreqs=false
radioline=6
userbds=true
