Page 46 of 139 FirstFirst ... 36373839404142434445464748495051525354555696 ... LastLast
Results 451 to 460 of 1381
Thread: HD Radio Cables READY!
  1. #451
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    Yeah, what he said. -^
    Also, I struggled until I capitalized hdradioport as "HdRadioPort" or "HDRadioPort" - I don't remember. I'm under the impression it's case sensitive because it began working after that.
  2. #452
    Constant Bitrate smp4488's Avatar
    Oct 2007
    Louisville, KY
    blk02si, Still no luck. I never hear the radio "click" on when i go to the radio page. Any more ides?
  3. #453
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    make sure your roadrunner.exe is the newest available. Unregister and reregister the DLL.
    Make sure your port setting is correct, sometimes PC's will do weird things with the ports if you have multiple things connected.
  4. #454
    MySQL Error
    Oct 2004
    it seems, just about everytime this happens, its because you're using the "test" version of the .dll
    the newest .dll is in this thread...
    drop it in, and "runme1st.cmd"
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #455
    MySQL Error
    Oct 2004
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #456
    Oct 2007
    Louisville, KY
    Ok, I have swapped out the dll's and re ran the batch file still no luck. RR is the latest version as well as all my skin item. The config has been edited with all the suggestions and still no luck. What am i missing?
  7. #457
    Jul 2005
    Motorcity
    Blog Entries
    1
    are you running a USB > RS232 adaptor or running straight to the serial port?
    If all is done as you say, and mitch's app works, RR has to be stealing your HD port assignment when it launches.
    I know it can happen because when I upgraded to IG4 it stole COM1 from the HD. When I launched IG4 it would turn on the relays in the HD radio and then turn them right off, and it rendered the HD menu useless.
    What other devices do you have plugged into the PC? Please list any USB.
  8. #458
    Oct 2007
    Louisville, KY
    Im not using the adaptor and i do have IG4. I changed the port in IG but right now the only usb devices pluged in are a hub and mouse. Nothing is plugged into the hub. I know what your talking about with IG because i hear the click when it launches also. I change the port, close it, relaunch to make sure its not on the same port.
  9. #459
    Dec 2007
    DC Metro area
    Did you try messing with the capitalization of "HDRadioport" in "HDRadioport=1"? I found that mine didn't work until I got the capitalizaiton just right.
    EDIT: Ok, just searched through forums (not by my carputer right now) and the correct capitalization should be:
    HDRadioport=1
  10. #460
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by smp4488 View Post
    Your problem is discovered then. If its clicking upon IG launching then its probing your HD radio port looking for the GPS dongle. Try changing the GPS dongle to a diff. usb slot and setting it to port 6 or 7.
    Also you can try what krnpimpsta has suggested although my HD radio works fine with all lower case in the rr.ini
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
