smp4488, get it working?
mitch
The GPS dongle is not plugged in at all right now. Should i plug it in and then try?
mitch
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
I got mine HD Radio installed over the weekend. I recieved my cable today (thanks Mitch). I cant wait to see it running on my computer. Now the problem is I fried my harddrive. Wired the IDE cable to the harddrive incorrectly. If anyone can help please reply to the post below.
IDE to Mini IDE Question
Once again thanks for the quick delivery Mitch. I am so excited to get it working. The reciever alone sounds awesome.
For the HD Radio, I see that there are 2 HD units you can buy....... do both use the same software and drivers or does each have its own? I ask because I know they will be working on a plugin for the Visteon HDZ300 for CF, but I'd prefer the cheaper one, my CarPC install is already way over budget
PS: Mitch I see under XM there is nothing. Do you make serial cables for the XM direct at all? If yes, I would like to buy one...
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
Mitch, still no luck and not alot of time to work beacuse of teachers cramming before spring break. All of the above has not worked for me so i have no idea what is up.
thanks mitch. got the cable today. i didn't even expect the audio cables as well. nice touch. now off to try install this fricken thing
Leonardo Da Vinci
Has anyone started on the centrafuse support??
David (creater of CF), is going to be working on a plugin. He says he has purchased the Visteon and Mitch's cable, so im sure it will be avaliable soon. He said he wants to get CF v1.48 out first before working on it. Go to Fluxmedia.net and check out the forums, it has everything you want to know.
PS: Thanx for the info GreatWhite
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
