Page 55 of 139 FirstFirst ... 5454647484950515253545556575859606162636465105 ... LastLast
Results 541 to 550 of 1381
Thread: HD Radio Cables READY!
  1. #541
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Hey mitch,
    Actually, everything is working as it is suppossed to, what I was hoping was that the functionality could be changed.
    I would like an option in the dll as to either 1. work as it does or,2. instead of shutting the radio on and off , hw mute the radio on and off as I described in the previous post.
    I am under the impression that you can control the mute of the visteon... your app does via the mute button right?
  2. #542
    MySQL Error
    Oct 2004
    yes... there is a SW Mute for the radio and is exposed in my interface class
    the HW Mute is not controllable by user
    but u dont even need that, just mute the LINE in when NOT listening
    how in RR, i dont know, sounds like a custom rr build thing
    does RR turn off the radio? when you leave the screen? or only when u exit...
    i guess i could set up answer my questions
    remember me no carpc person
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #543
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by mitchjs View Post
    mitch
    From the sound of it, (clicking) RR is turning the tuner on/off when switching media to/from RADIO.
    It would be nice to just have it on, but muted when listening to AUDIO, VIDEO, etc. to save the few secs of lag when switching media...
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  4. #544
    Mar 2008
    Toronto Canada
    When I select "Radio" in any skin, the visteon relay clicks, then some slight popping sound and then after a couple of seconds, you hear radio.
    The radio always stays on unless I select a "Music" skin or "Video" skin. At this point you hear the radio click off. When I select "Radio" again the relay clicks, radio turns on ..etc...
    What I want is for the radio to stay on so that I can just mute the line in like you suggest and not have to wait for the radio to turn on and off.
    Is this the behaviour that you other RR users experience?
    It is totally usable as is, but would be faster and smother if the radio didn't turn on and off.
    BTW im using the winamp linein plugin for now if that makes any difference, oh and I my radio settings in rr.ini are as follows...
    [Radio]
    radiomode=8
    allowallfreqs=false
    radioline=0
    uselineinplugin=true
    lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
    userbds=false
  5. #545
    MySQL Error
    Oct 2004
    ok, need GUINO's help here, to have him do radio a different way
    he coded hd radio based on his other radios...
    so it would slip right in...
    i agree, it should power on tuner, at load... and keep it on, till shutdown/sleepy
    Guino, can you do this? ( i know u can )
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #546
    MySQL Error
    Oct 2004
    pcpete, i dont know how rr manages audio... but it looks like YOU DONT have to use the line in plugin... if your radio is connected to the same mixer device as the speakers
    there should be a monitor pin in the mixer...
    i dont know if RR can control that
    id think its related to "radioline=0" but that may only control CAPTURE pins...
    guino can answer that.. or somone can try it
    (i might set up and play)
    but even using winamp... its just a simple thing to mute line in... id think
    or guino can add the call to the mute in the hdradio class
    i cant see what he does, since i dont think there is souce of RR out there that has the hdradio code in it...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #547
    Mar 2008
    Toronto Canada
    Thx for looking into this mitch (and guino hopefully too), as this would really make it more seamless.
    As for using the linein winamp plugin, its because my soundcard is an M-Audio FW 410 and it's linein isn't part of the windows mixer.
    Anyone else using this audio interface?
  8. #548
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Mitch,
    I don't know if everyone has this issue, but I've seen it posted before:
    When starting the pc, I can hear the visteon freaknig out (on/off/on/off)as the serial port does it's thing.
    Might this article be a solution to the issue:
    http://dast.freeshell.org/blog/title..._ports_serenum
    cheers
    Leonardo Da Vinci
  9. #549
    Mar 2008
    Toronto Canada
    Good find Greatwhite, mine freaks aswell, think I'll give those a try
  10. #550
    May 2007
    Quote Originally Posted by pcpete View Post
    let us know if it works. I haven't got time to go mess with the car right now..............
    Leonardo Da Vinci
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
