Page 56 of 139 FirstFirst ... 6464748495051525354555657585960616263646566106 ... LastLast
Results 551 to 560 of 1381
Thread: HD Radio Cables READY!
  1. #551
    Newbie MusicMonkey5555's Avatar
    Mar 2008
    Kirkland, Washington, United States
    Just got my cable a couple of days ago, but I went back to the site to get the drivers and I noticed the item wasn't on there anymore. Is he updating the page? Will it be back on there in a couple of days? not a big deal because I won't be able to finish my system until the monitor I am going to use is finished, but I was just wondering what was up.
    2007 Ford Focus
    Project Page
    Software - Win7, Centrafuse, Firefox, MediaMonkey, Trillian
    Hardware - Intel X25-M 80GB SSD , VIA C7, Jetway J7F5M-VDE, Kingston 1GB RAM, Preassembled 2Din Frame w/7" Lilliput EBY701
    Planning: 85%
    Parts: 95%
    Install:75%
  2. #552
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    I think its just normal for Visteon to trigger on/off when the pc resumes hibernation or turns on. I guess the driver is just sending power and enabling the radio on/off at startup.
    My carpc worklog
  3. #553
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by rgarjr View Post
    Nah, you can hear it clicking on and off several times. Mitch thinks it's windows looking for a modem or somethingo n the serial port.
    Been discussed before........
    Leonardo Da Vinci
  4. #554
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Quote Originally Posted by greatwhite View Post
    let us know if it works. I haven't got time to go mess with the car right now..............
    Same here, I'll see if I can sneek out after the wife and kids fall asleep....
  5. #555
    MySQL Error
    Oct 2004
    back on site, only 3 left... then 10days or so till more
    its windows looking for a serial mouse...
    does that SkipEnumerations thing work, dont know
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  6. #556
    MySQL Error
    Oct 2004
    YES... disabling the serialenum, will keep windows from looking for devices on that comport... and the radio wont click on and off...
    now i use a ftdi based usb->rs232, so if you do too... just got to the windows devicemanager, and under the ports, find the comport in question, go to port settings...advance and uncheck the "serial enumerator" check box
    that simple...
    for onboard serial ports my guess it add the dword string
    as described in this article
    http://dast.freeshell.org/blog/title..._ports_serenum
    basicly, most onboard com ports are plug and play, so it will be in
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\A CPI
    to find out which device look at
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Serenum\Enum
    it will list the devices that the serenum service is testing
    for instance mine ACPI\PNP0501\1
    so then back to the other key
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\A CPI\PNP0501\1
    then do a SkipEnumerations dword key in the "Device Parameters"
    set it to -1 (dec) or 0xffffffff
    should do it... i will test mine...
    the ftdi usb sure makes it easy
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #557
    Jan 2008
    Covina, CA
    I have an FTDI chip based converter as well and will give it a spin and see if it works.
    My carpc worklog
  8. #558
    MySQL Error
    Oct 2004
    happy to report that it works perfectly...
    no more click click, not that it was a big deal anyway...
    SkipEnumerations added to a onboard comport
    if you're using usb->rs232 like me (ftdi)
    and unchecking "serial enumerator" in the control panel port settings advanced
    thanks, to the person who discovered that article...
    i learnededed something
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #559
    May 2007
    Quote Originally Posted by mitchjs View Post
    mitch
    You're welcome.
    Just gotta get it workng on my setup now.....
    Leonardo Da Vinci
  10. #560
    Mar 2008
    Toronto Canada
    Just tested on my setup ;
    mitch cable -> direct to serial on motherboard .. no more freaking
    my key for com1 was:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\A CPI\PNP0501\1\Device Parameters]
    "FirmwareIdentified"=dword:00000001
    "PortName"="COM1"
    "PollingPeriod"=dword:00000000
    "SkipEnumerations"=dword:ffffffff
    The bolded part is what I added, may be different depending on system..
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
