Page 63 of 141 FirstFirst ... 13535455565758596061626364656667686970717273113 ... LastLast
Results 621 to 630 of 1408
Thread: HD Radio Cables READY!
  1. #621
    Newbie diggs's Avatar
    May 2008
    Central Ohio
    Quote Originally Posted by HiJackZX1 View Post
    Have you tried lowering the volume for line-in and mic-in... If its too high it will sound distorted, almost like they are talking right next to the speaker and trying to blow it out...
    I have, and it's turned down very low (like 1 on a scale of 10), although perhaps I'm underestimating the level of lowness it needs to be at. When I get home I'll try adjusting it to just above mute and see if it makes any difference.
  2. #622
    MySQL Error
    Oct 2004
    u are prob over driving the MIC-IN
    some mic-ins, have a MIC-boost option, in the audio settings turn that OFF
    I wouldnt use the MIC-IN, i would get myself a USB AUDIO IN DEVICE
    or just move all audio to usb, a usb audigy or something like that
    a simple USB AUDIO IN, is dirt cheap, if u use that u need to move the audio acrross devices... so thats the winamp line in plug in...
    what are u even using for audio out, the laptops 2 channel audio out?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #623
    May 2008
    Central Ohio
    Quote Originally Posted by mitchjs View Post
    mitch
    I'll look for that boost option and see if I have it. I'll also try to find a USB audio-in or sound card (hopefully locally).
    I'm using the headphone out on the laptop.
  4. #624
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    mitch brings a good point.. for those of us missing line-ins audio capture devices may just work. I'll have to test mine out.
    Live mp3Car Facebook Chat
  5. #625
    May 2008
    Central Ohio
    It was the Mic Boost option, I un-checked it and now it sounds great! Thanks, Mitch, for the help AND your fantastic cable
  6. #626
    MySQL Error
    Oct 2004
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #627
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    It has a config file... all you have to do is change the com port assignment to what ever the parrallel port is set to, and put it on pin 4 of that...... should work, wouldnt hurt to try....
    Would it still be pin 4 on a Parallel port?
    I seen the config file and figured that could be edited for the parallel port. Just wanna make sure that it's the right pin.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  8. #628
    Oct 2007
    Just wanted to chime in here on the echo. I know with my Audigy sound card, I have to mute the WAV input to get rid of the echo. I'm looking for a way to do this prgramatically when HD starts fromt he DFX3.0 skin. Right now I just mute it manually wehn I want to listen to the radio, but that is "clunky". Anyone know how to do this from the skin?
  9. #629
    Mar 2006
    Pennsylvania
    Ok, so I take it DTR is pin 20 on a 25 pin parallel port, according to this chart...same as pin 4 on a 9 pin cable. Wanna make sure so I dont fry anything.
    DB-9 to DB-25 Adapter or Cable
    Used to adapt serial ports to the proper size
    25 Pin 9 Pin Signal-RS232
    Connector Connector
    1 n/a Protective Ground
    2 3 TX Transmit
    3 2 RX Recieve
    4 7 RTS Request to Send
    5 8 CTS Clear to Send
    6 6 DSR Data set Ready
    7 5 Signal Ground
    8 1 DCD Data carrier detect
    9 n/a + Transmit
    11 n/a - Transmit
    18 n/a + Recieve
    20 4 DTR Data terminal ready
    22 9 RI Ring Indicator
    23 n/a DSRD Data signal-rate indicator
    25 n/a - Recieve
    ccrum...thanks for the info. Unfortunatley, it didnt work with mine.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  10. #630
    MySQL Error
    Oct 2004
    PontiacGA, thats NOT a parallel PORT!!!!
    a parallel port = (old style printer port)
    not used by anything anymore
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
