Page 66 of 141 FirstFirst ... 16565758596061626364656667686970717273747576116 ... LastLast
Results 651 to 660 of 1404
Thread: HD Radio Cables READY!
  1. #651
    Aug 2005
    Quote Originally Posted by mitchjs View Post
    pontiac, how about just buy a usb to serial, connect the HD Radio to it
    get one of these...
    http://www.mouser.com/Search/Refine....0895-UC232R-10
    mitch
    Mitch,
    Is this the recommended cable for your setup? I also do not have any serial ports available on my computer and need a good serial to USB cable. This is somewhat off topic, but can you recommend a good USB hub for carpc applications? I only have 4 ports on my computer and adding this HD Radio setup will take up all my ports! Thanks!
  2. #652
    MySQL Error
    Oct 2004
    pontiacga, not ANY pin, but A pin
    best to use the 1st bit... PIN #2 will go high when RR is running and low when not
    course what bios/and OS does while booting i dont know...
    connect to pin #2 and see if it works ok while booting, ie amps stay off
    if u want the special RR build (with lots of other screw ups in it) PM me
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #653
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Ok, I'll try that and get back to you. Hope this works.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  4. #654
    MySQL Error
    Oct 2004
    hmm, my PIN D0 goes high, when OS boots... well durning the boot
    so.. not ideal... I assume its the OS looking for a printer on the port, that does it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #655
    Mar 2006
    Pennsylvania
    Connected it to pin 2 and it works great. Works outside of RR too. I still get a loud pop when the puter turns off. No biggie.
    Now, if I can find a way around the stupid radio issue of working on all 4 channels instead of only 2.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  6. #656
    MySQL Error
    Oct 2004
    well... u can prob use my cmd line program, that turns off that pin
    or my build of RR would do it
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #657
    Mar 2006
    Pennsylvania
    Where can I get said cmd line program?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  8. #658
    MySQL Error
    Oct 2004
    good question
    here...
    usage:
    ampctrlc 1 turns on pin d0
    ampctrlc 0 turns off pin d0
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #659
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    Finally got the HD radio/Cable installed and well.....Dayum!! Can't believe I put this off.
    Sounds fastastic and the cable worked flawlessly. Just started up and it worked. (can't believe how many stations it picks up)
    Thanks!!
    My opinion is my own.
  10. #660
    MySQL Error
    Oct 2004
    danielkh, which front end sw u using?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 07:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 01:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 05:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 02:48 AM
