Page 7 of 139 FirstFirst 123456789101112131415161757107 ... LastLast
Results 61 to 70 of 1381
Thread: HD Radio Cables READY!
  1. #61
    May 2006
    IL.
    AM not working?
    I got DIRECTED DMHD1000 and cable from Mitch (thanks for fast service), downloaded latest RR and New Age Bellissimo skin (for HDRadio support).
    Everything is setup by information in other threads (.net 2.0, runme1st, radiomode=8, HDRadioport=1).
    Radio is working fine on FM, but I can't change band to AM. Is it supported by RR?
    Checked "BAND" button setting in NAB and HDRadio skin for LSX Void 3 skin and both are set to:
    Code:
    "BYIND;FMAM;FMPRESET;PRESET1<<FMPRESET;PRESET2"
    Is it right?
  2. #62
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    this is right.. at this point there is no way to switch to AM.
    Live mp3Car Facebook Chat
  3. #63
    Newbie Nanner's Avatar
    Aug 2007
    San Antonio
    There is a way to enable the band button. Use the code you listed for the band button code. In the RoadRunner folder create two text files, preset1.fm and preset2.fm. Open each one with notepad and enter a valid station number ie: 10750 for fim and 860 for am. Those are the ones I used for my band button and they are actual location stations in my area. When you press the band button it should change the band between fm and am and set it to the corresponding station.
  4. #64
    Woodbridge, VA
    Blog Entries
    32
    well thats one way to handle it but it should be easier... Mitch's app has a band button that rr should be able to work with.
    while we're about requests, can we get a RADIORESET command that's purpose is to close and re-open the hdradioport? When i turn off my car while the computer stays running i lose the radios connection because the unit has technically been powered off when the car is off. To cure this ihave to go to my audio skin then back to my radio skin so that rr re-opens the port.
  5. #65
    May 2006
    IL.
    I have another request for SEEK mode (all / HD only) which is implemented in Mitch program.
  6. #66
    Nov 2006
    Kudos to Mitch for the cable and fast shipping! I finally got my hd working, It is so much better than my silabs.
  7. #67
    Newbie hugenius79's Avatar
    May 2006
    New York
    New_AGe_HD_Radio howto
    You can switch to AM by Direct tuning.
    Then save button 1 to FM frequency and button 2 rto am frequency..
    The use the band BUTTON to switch AM/ FM ..
    Illustration below...
  8. #68
    Jun 2002
    Virginia
    @ Sonic: I've been following this thread pretty closely and may be interested in getting in on the HD radio. Since I'm also in NOVA, I'm wondering if you've been able to find lots of stations and good reception here.
    @All: Also, I'm wondering how people are hooking the units up to their car antennas.
  9. #69
    Woodbridge, VA
    Blog Entries
    32
    i've very happy with my purchase now that its all up and running in rr like it should. MOST of the mainstream channels in the area carry the HD stream, but it appears most do not have subchannels. Honestly to me (for now at least) this hasnt been a really big deal. I'm having a weird interference issue now... for some reason i get better reception closer to my home if my back seat is down lol. I'm thinking a signal booster should help that though. My directed tuner is in the back on top of my computer and i'm using BOTH cables the directed unit comes with in order to have a cable long enough to reach my stock antenna plug. Most people will overcome this by placing the tuner up where the radio should be.. and that might be what i end up doing if i cant get my interference issues sorted. Overall though i'm very satisfied with the purchase.. but i was in it for a FM/AM replacement first and the HD thing is a bonus.
    In terms of hooking it up to your car antenna the unit comes with everything you need to do that. The tuner has an antenna IN and antenna OUT ports.. so if you are using your stock radio you can run the antenna through both the stock radio and the tuner. Grab mitch's cable, grab one of the tuners and you have everything you need to get this hooked up and running.
    Hey mitch, what are the chances.... or should i say how easy would it be to create a splitter that allows you to control the unit via RR AND display with the LCD included in the package? I'm thinkin i'd like to know whats available on the radio even when i'm not listening to it.
  10. #70
    Jun 2002
    Virginia
    Thanks, Sonic. My interest in this has more to do with wanting to have the latest and greatest than having a need. If it's not blowing you away and comes only at a fair amount of expense and hassle, I'm probably going to leave well enough alone.
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
