Mitch......stay calm.....no, that isn't what I am saying. I told you the other day that I run SD also with your radio interface in the background. Without even starting RR, the levels are back high (90 as you say).
have i not explained?, that the VOLUME is SET by what ever controls.... the tuner (SW)
it has to be set, infact the tuner powers up with VOLUME AT 0
and its not really a volume in the triditional sense, lets call it a output level
the tuners OEM display is just Software too
mitch
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
My opinion is my own.
also.... if DTR drops, the radio is OFF... so u cant really exit RR and keep the radio on...
but... if u need the level lowered, we can do it!
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
yea, i missed the SD thing... i didnt know what SD is (SORRRRRY)
its Street Deck.... i not fimilair enough with it... i know it doesnt directly control HD
my radio interface? you mean HDRadio PCR?
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
That takes us back to the original post. I really don't NEED it fixed, at 5% gain, everything was working fine, but since this became such a big issue, we either have to work it out or avoid each other, and anyone that knows me knows I prefer option 1.
We HAVE to understand where the other is coming from.
So stay calm and lets work through this. ok?
5% doesnt give u much room to tweak
now, with RR set at 90, it should be distorted a bit
but my PCR, set it at 75, and that should be OK, its it too hot still?
HDRadioCore.SetVolume(0x4b);
i assume ur uptodate on hdradio pcr.... not that a new version came out latey
but... u should have
everyone should have
HDRadio PCR V1.3.0.1
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
daniel, do u want me to have all the posts that we argued on, deleted? and start over?
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Heck, they're entertaining, so doesn't matter to me. Past is past. And yes, I deleted that post on the other cable because I decided that was no better than some other things I have been criticizing here on another thread.
It isn't constructive and will just make things worse. The problem was that I really thought you were misunderstanding my issue and I was misunderstanding your responses. Early on, you said you could control the audio 100% in RR. After that, I never saw where you mentioned the Visteon.
5% gain really isn't that distorted. I still have 0-100% in RR. Anyway, let's move on.......is there a way to force mute line in (xm radio) using your RR? Meaning that when I switch from xm to hd it will mute xm.
ok, i argee enertaining...
this was in the RR forum, someone moved it heheh
ok, now... in my RR... when you switch to XM, i HARDWARE mute the XM
note im not mentioning the PC... cause i dont touch the PCs line IN
but RR does... when XM BECOMES INACTIVE, 2 things happen, the LINE in that is set in the RR.ini is muted, and my code tells XM HARDWARE to mute
and when XM is ACTIVE, everyone unmutes
SAME for HD Radio...
basicly, XM and HD are ALWAYS on, what u "HEAR" note "HEAR" depends on the PC's line in mute, and which radio is ACTIVE
in the NON my version of RR, distorted?, i found that max volume of 90 had some distortion...
but i use 75, which is the same as the visteon display
mitch
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
