ok, i argee enertaining...
this was in the RR forum, someone moved it heheh
ok, now... in my RR... when you switch to XM, i
HARDWARE mute the XM
note im not mentioning the PC... cause i dont touch the PCs line IN
but RR does... when XM BECOMES INACTIVE, 2 things happen, the LINE in that is set in the RR.ini is muted, and my code tells XM HARDWARE to mute
and when XM is ACTIVE, everyone unmutes
SAME for HD
Radio...
basicly, XM and HD are ALWAYS on, what u "HEAR" note "HEAR" depends on the PC's line in mute, and which radio is ACTIVE
in the NON my version of RR, distorted?, i found that max volume of 90 had some distortion...
but i use 75, which is the same as the visteon display
mitch
