Page 77 of 139 FirstFirst ... 27676869707172737475767778798081828384858687127 ... LastLast
Results 761 to 770 of 1381
Thread: HD Radio Cables READY!
  1. #761
    MySQL Error
    Oct 2004
    pontiac, no it doesnt "AudioRepeater" does not create echo!!!
    you need to understand how audio in windows(OS) works! (or kinda)
    put away RR for the moment...
    a windows audio system (not talking vista, but vista is close(actually better) then XP)
    there are inputs and outputs, lets call them PINS
    you got playback pins, and record pins
    a playback pin, will let you listen to a audio input LIVE, never being processed by the CPU of the PC
    so.. if you got say a LINE IN, and you go to the playback section of the mixer, and unmute its PIN, you will hear what comes in on that line in...
    NOW in your case, MUTE ALL the PLAYBACK input PINS... LINE IN, CD, AUX, what ever they are, they vary from sound card to sound card...
    this is done in the windows mixer
    now go to the record section of the mixer... there are PINS there
    select only the LINE IN PIN, when you activate it you wont hear anything...
    now use "Audiorepeater", in the IN, select the LINE IN (PIN)
    and the out, wav mapper is fine... or direct to speakers
    set up u speaker config you want quad... and click start...
    at this point, if u got audio playing on you line in... you will hear the audio
    on all 4 speakers, NO ECHO!
    now RR, is limited on how it manages audio... basicly you do NOT want to use "linein" method
    cause they are on the PLAYBACK PIN side of the mixer
    for instance.. radioline=0, xmline=0, so fourth...
    and u want all your PLAYBACK input PINS Muted
    then you need RR to use "audio repeater" (since it take cmd line)
    to do your audio
    OR winamp LINE IN plug in, with a line out plug in, would do..
    as long as winamp line in plug in, uses the RECORDING PINS, and doesnt touch playback PINS
    if you need one on one help... id be happy to help you via email or better yet IM
    I started a conceptuall audio management system while back... but since like you guys already know, i dont USE RR, i never finished it... but i use it alot since my machine has multiple sounds cards/usb devices, and i can play back audio from any device to the speakers on the onboard device
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #762
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by danielkh View Post
    Is this for #4?
    AMPCTRL is for pin #4. The other software VOLUME_AMP_CONTROL (I think its called) uses pin #4 also. Daniel how is AMPCTRL working for you? I am having a issue were it takes almost one minute to turn on the amps, and after a few hibernations i get no sound. Im thinking of ditching AMPCTRL and using the VOLUME_AMP one.
    Also, Mitch, I like your USB, line device thingy... looks very small. I did get the Auto A/V switch and it hugeeeeeeeeeeeeeee. So it would be awsome to use yours. Can i be a beta tester?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #763
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon
    I only have a few days testing under my belt, and so far, it works fine (ampctrl). Remind me in a week or so or if I have problems I'll let you know. By the time rr is running, I have amps.
  4. #764
    Jul 2007
    Miami
    Cool, i'll be waiting, although Im going to uninstall it and try the other.
    Also I got the A/V switch thing in. Its pretty cool. I tested it on my PS2 and XBOX 360. First I turned on my PS2 and it automatically switched to Port 2. I then turned on the 360 and it switched to that item. I then turned off the 360 and it went back to PS2. I read somewhere that the XM stays on all the time with CF, but I know the HD radio shuts off because I hear it click off. So this is perfect, but like I said the size of the unit is cr@ppy
    PS: nevermind, it doesnt work with only audio, you have to have a video feed for auto switch... so looks like Mitches device is the best way to go.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  5. #765
    Sep 2007
    Beaverton, Oregon
    Quote Originally Posted by HiJackZX1 View Post
    Also I got the A/V switch thing in. Its pretty cool. I tested it on my PS2 and XBOX 360. First I turned on my PS2 and it automatically switched to Port 2. I then turned on the 360 and it switched to that item. I then turned off the 360 and it went back to PS2. I read somewhere that the XM stays on all the time with CF, but I know the HD radio shuts off because I hear it click off. So this is perfect, but like I said the size of the unit is cr@ppy.
    You know, I wonder if the fact that I am using everything onboard now (especially sound), if it will have a problem. MoBo seems really REALLY smart. Probably the best motherboard I have ever owned. And that's saying a lot when the first computer I ever built was a 286 (and could double as a coffee table).
    My opinion is my own.
  6. #766
    Jul 2008
    Thanks michjs for the cables. Your customer service is great and your shipping is fast. I didn't know you included the RCA to 3.5mm cable, but it save me a trip to Fry's or having to wait buying it online.
  7. #767
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    I believe I got it working!! Sounds SO much better!!!!
    This works with RR. What I did was keep the Line-in muted and the WAV unmuted in the playback.
    In Winamp plugins, under Input, use the LineIn Plugin v1.80. Under Output, use Directsound and chose 'Virtual Cable'. Everything else is left default in those two.
    In AudioRepeater, Wave in should be set to Virtual Cable and Waveout should be MS Sound Mapper. In Channel config, select Quadraphonic (Or 4 channel, depending on what version of VC you have)
    Now, in RR, make sure the linein stays muted and the WAV stays unmuted. Also, make sure you have the linein option checked in the RR config.
    Finally!
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  8. #768
    MySQL Error
    Oct 2004
    pontiacga, glad to "hear", its all about audio management! (understanding the mixer)
    dabopper, thanks!
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #769
    MySQL Error
    Oct 2004
    Little HD Radio Cable update, they now are 5 feet long, 2 extra feet!! woohoo
    hope everyone is having a nice long weekend!
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #770
    Jul 2007
    Miami
    Quote Originally Posted by mitchjs View Post
    mitch
    Mitch start a new thread on the line in device, so you can keep us posted....... I so want one.....
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
