Page 84 of 141 FirstFirst ... 34747576777879808182838485868788899091929394134 ... LastLast
Results 831 to 840 of 1405
Thread: HD Radio Cables READY!
  1. #831
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Quote Originally Posted by danielkh View Post
    With the head unit removed (?), if you have a powered antenna, make sure it is getting voltage. If the head unit powered it, it won't (blue wire). I thought I had broken my antenna. When I found that, the Visteon blew the factory HU out of the water on reception.
    Nope. No power antenna. It's a little stubby one on the roof.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  2. #832
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    My bad. Power as in amplified internally (newer ones are). Not powered as in up and down.
  3. #833
    MySQL Error
    Oct 2004
    PONTIAC, you need to power that up, and hope... and if reception is still bad... id prob put back in the factory radio and sell the car
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #834
    Sep 2007
    Mitch, I finally had time to work on the XM. Not sure if you remember, but I mentioned having engine noise (ground loop). Just to get this out and posted for the masses, I used this cheapy and it worked beautifully. I totally forgot how good Watercolors (XM Channel 71) could sound....
    http://www.radioshack.com/product/in...entPage=search
    My opinion is my own.
  5. #835
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    is the bad reception the hdradio period or is it being run in conjunction with your pc?
    my stock and aftermarket radios worked fine. hdradio by itself worked fine... but once you used the radio with the pc it would DIE. as recently stated, sealing my pc components (and i really do mean pretty dang tight) fixed the RFI noise that was being generated. in my case, it was the M2-ATX power supply causing RFI
  6. #836
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    You dont have any muffled sound with the RadioShack version? I bought mine from Best Buy, its called a InstallEdge Ground Loop Isolator. This one promises 100% clarity, and a 3db gain. i think its 1 dollar more then the one you pointed to.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  7. #837
    Sep 2007
    Quote Originally Posted by HiJackZX1 View Post
    Crystal clear. Sounds like the mp3's now. But keep in mind I am deaf in one ear and can't hear out of the other.
    But no, no muffling. I was listening to jazz (watercolors) and if anything would show muffling, that would.
  8. #838
    Jul 2007
    Miami
    LOL, I am also deaf (not 100%), all I hear is certain frequencies and this horrible ringing 24/7.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  9. #839
    MySQL Error
    Oct 2004
    What?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #840
    Mar 2006
    Pennsylvania
    Quote Originally Posted by utd09bry View Post
    Think you're on to something. I had to put an adapter cable on the ant. cable. I moved the connector behind an aluminium shield and the radio came in clearer. So, I'm gonna work on shielding the connector better. Thanks for the tip.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 07:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 01:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 05:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 02:48 AM
