Page 85 of 141 FirstFirst ... 35757677787980818283848586878889909192939495135 ... LastLast
Results 841 to 850 of 1408
Thread: HD Radio Cables READY!
  1. #841
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    just another tip... if you are experiencing interference (which remember, PC's are notorious for RFI/EMI), you will have a much better result by sealing the source than trying to filter or hide the object that is receiving the interference.
    in my case, i tried many things to isolate my antenna cables and radio box... but nothing really worked. i technically got it to sound ::better:: but not great. it wasn't until i sealed up my pc components that i eliminated the problem (at the source). definitely give that a try if you happen to have your computer parts unshielded.
  2. #842
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Ok... I downloaded your RR files and followed directions. Ran the register file in main RR folder then went into HD radio. It would not register HDradiocom.dll or something like that. I tried this on both systems. The radio works but RR is now all messed up.
    When I try to register the batch file labeled "Register" it says this
    "HDRadioComm.dll was loaded, but the Dll Register server entry point not found" "This File cannot be registered"
    Now my radio isn't working at all in RR. Works on the PCR still.
    Dougw133 is online now Report Post Edit/Delete Message Reply With Quote
    Alright I realized I am in the worng thread but if anyone knows of any fixer here please let me know?
  3. #843
    MySQL Error
    Oct 2004
    what batch file "register"? who the hell is com registering my dll!
    define "downloaded your RR files" and where are you getting these
    i could assume some, but youre for sure in wrong thread, but thats ok, ill prod you a bit
    if your using my special RR build...
    try, "MJSG-RR-RunMe1st.cmd"
    if youre not, look in the HDRadio Directory... "runme1st.cmd"
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #844
    Nov 2007
    PA
    Yeah I am I realized that.. Sorry
  5. #845
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Quote Originally Posted by utd09bry View Post
    Would getting a small plastic case from radioshack and sticking the PSU in it help at all? Or does it have to be metal?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  6. #846
    MySQL Error
    Oct 2004
    yea metal, and grounded
    you might not be able to eliminate it, which is then time to get rid of it
    maybe a different ps
    switching supplies always make RFI, its unavoidable... but some are just sloppy, and make tons of noise
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #847
    hmm i seem to be having an issue where on the initial start of the HDradio program (both in RR and standalone, where the output of the visteon is EXTREMELY loud, making my clipping indicatiors of my sound card go on and of course the sound is distorted...
    however, after switching to another station, the volume returns to normal and the stations come in clear. does anyone else have this problem?
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  8. #848
    MySQL Error
    Oct 2004
    Quote Originally Posted by miztahsparklez View Post
    NO problem here, try the audio mod
    are u using MY BUILD of RR?
    look for it, basicly gnd the rcas
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #849
    Quote Originally Posted by mitchjs View Post
    mitch
    which is your version? im using the newest stable RR release (before the weather fix) with the newest version of the LSX skin. This not only happens in RR but also your HDR program. The gain on the outputs are set way high distorting the sound during initial power on. But, after you change stations, it goes back to proper levels and there is no issue. It seems like when it first initializes theres something that makes it too loud then corrects it after a command is sent to it.
    The same thing happens both on my bench setup and in the car. On my bench setup i tried doing the grounding thing (it wasnt distorting at the time either) with no change in sound.
  10. #850
    MySQL Error
    Oct 2004
    dont know then.... u are using the latest HDRadio PCR right?(not that any new one came out in a long time) but be sure
    but my build of RR, does set HD Radio volume at the right level
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
