Page 88 of 139 FirstFirst ... 38787980818283848586878889909192939495969798138 ... LastLast
Results 871 to 880 of 1387
Thread: HD Radio Cables READY!
  1. #871
    FLAC WuNgUn's Avatar
    Sep 2007
    Hey Mitch...I switched mainboards and it needed a serial port adapter plate attached to the mainboard...
    I installed one, but the Visteon radio isn't working. I hear it power on when I run your software, the port shows up, but it tells me there is a communication error and stops.
    Maybe a non-standard pin-out on this boards serial port?
    Here is the pinout...
    1 DCD Data Carry Detect
    2 SIN Serial In or Receive Data
    3 SOUT Serial Out or Transmit Data
    4 DTR Data Terminal Ready)
    5 GND Ground
    6 DSR Data Set Ready
    7 RTS Request To Send
    8 CTS Clear To Send
    9 RI Ring Indica
    Good or bad? What could be the matter?
    BTW, Centrafuse doesn't even see the radio
  2. #872
    MySQL Error
    Oct 2004
    thats all good, ur running HD RADIO PCR right?
    you hear radio click?
    should just work
    there is nothing tricky here...
    try another computer to be sure
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #873
    Sep 2007
    Quote Originally Posted by mitchjs View Post
    should just work
    mitch
    Yup, I hear it click...
    It searches the COM ports, then gives me 'communication error'
  4. #874
    MySQL Error
    Oct 2004
    dont know, try another pc
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #875
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    same thing happened to me when i put on my gps dongle. its usb, but uses a 'serial port' according to device manager. after that, i couldnt get it to work. did you run anything else like that?
    @mitch
    If my GPS program was making the visteon click on/off when searching for my gps dongle, could this ruin anything in the visteon potentially? i havent tried the visteon on my other mobo yet, but just theoretically, could it have sent a bad signal or anything?
  6. #876
    MySQL Error
    Oct 2004
    doubt it can "ruin" it, the gps program is just seaching comports for its puck
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #877
    Low Bitrate bigbuffs's Avatar
    Nov 2007
    I'm having probs gettin mine to work right. Using the visteon and I can't get any sound when I use mitchjs' program. It does tune to stations though so it is connected the the hd radio. However, I can get sound in RR radio when I don't use the cable and just run it off the face.
    Also, I can't control the radio in RR but I do have the latest RR release. I'm sure this is just some sort of audio input issue as far as getting the sound to work with the HD radio program. Not sure what I need to do to get control in RR.
    [||||||----] - 60% Complete
  8. #878
    MySQL Error
    Oct 2004
    u have to understand how audio works in windows
    and i assume you have the rca's connected to the pc's line in
    so its knowing how to use your sound systems MIXER
    as for RR, latest release is vague
    but in the rr.ini at the minimum you need:
    radiomode=8
    hdradioport=x where x is the comport its connected to
    not to mention a skin that supports HD Radio would make it nice too
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #879
    Sep 2007
    mitch
    Hey Mitch, can you recommend me a make of USB to serial RS232 adapter that's compatible?
    MySQL Error
    Oct 2004
    yes, FTDI chipset based, like
    http://www.mouser.com/Search/Refine....=895-UC232R-10
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 07:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 01:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 05:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 02:48 AM
