Page 92 of 141 FirstFirst ... 42828384858687888990919293949596979899100101102 ... LastLast
Results 911 to 920 of 1408
Thread: HD Radio Cables READY!
  1. #911
    Low Bitrate lor109's Avatar
    Mar 2004
    I'm not using Fadevolume. Another thing that has started resently with the new RR that might be related is when I restart RR my Winamp Volume is set to 0.
    Any other Ideas?
  2. #912
    MySQL Error
    Oct 2004
    that sounds like fadevolume to me
    make sure, in ur rr.ini
    fadeinvolume=false
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #913
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by lor109 View Post
    Any other Ideas?
    I have been having this problem from the day I hooked it all up!
    "Still having my age old problem. When I switch from HD radio Back to "MP3" in RR/DFX4 the volume is set to zero. Now, when I switch from MP3 to HD radio it works flawlessly and instantly. I still have no idea what to do. I have installed the latest RR in hopes that would work. Should I have deleted all the old HD radio files before doing the new install?
    Thanks..... Oh an yes mitch, I do not have fade in volume enabled "
  4. #914
    MySQL Error
    Oct 2004
    switch to the skin supplied with the RR installer (carwings)
    as for deleting, your posts doesnt give me ANY real information
    I have NO idea what version of RR you're even using
    using winamp line in plugin?
    attach ur rr.ini for review...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #915
    MySQL Error
    Oct 2004
    and what volume? there are tons of different volumes typically on a PC
    winamp volume?
    go simple, switch to carwings!
    could be ur mixer presets
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #916
    Nov 2007
    PA
    Alright well I have sorted it out. So many variables..
    The problem was in RR.Config. Not RR.config but the way I had it. I enabled and disabled winamp line in plugin and still nothing changed. What worked was "Disabling" the source selection (to mute when HD radio is not on). I had it set to AC3. I disabled it all together and enabled winamp line in plugin and it works! Thanks for the help, and I never meant to imply it was the radio or cables fault, just consulting the expert. I would smack a screen shot up but I am on my desktop. Try this out lor109.. Winamp Line In Plugin (make sure it's installed in winamp) enabled. In RR.config, source "Disabled". Set fade vole to False as stated above. Let's see if that works for you too.
    Thanks again!
  7. #917
    MySQL Error
    Oct 2004
    BUY NOW, 5 left, will have to wait 10-15 days, if i run out on ya
    im still seeing these on ebay, the visteons, still the best tuner fro carpcs!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #918
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Mitch,
    I know you made the (HD) cable and the adapter for XM and Sirius but will you make a cable or adapter for the XM NavTraffic tuners to interface with a PC? or any new projects on the horizon?
    Gee
  9. #919
    MySQL Error
    Oct 2004
    no plans of xm navtraffic... never even seen one
    also who knows where xm/sirius is going...
    yes, new projects... but what... hmmm
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #920
    Newbie Bmrbch's Avatar
    Aug 2008
    DIRECTED DMHD1000 problem
    Hello,
    I bought the cable, it looks great, but it does not recognize my DIRECTED DMHD1000. I have the PCR software. When I auto detect or use COM1, there is an audiable click and then says "cannot find HD radio". Also, in RoadRunner, the HD radio button hangs the program. Any ideas? THanks
    -Brian
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
