Page 94 of 141 FirstFirst ... 4484858687888990919293949596979899100101102103104 ... LastLast
Results 931 to 940 of 1408
Thread: HD Radio Cables READY!
  1. #931
    MySQL Error
    Oct 2004
    also, how about ur wiring, the HD Radio MUST BE ON WHEN PC IS ON
    Yellow to 12v constant, red to 12V Hard Drive Power
    NOT Ignition!!!!!
    iguidance ???
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #932
    Jun 2008
    Seattle, WA
    Why not ignition? That's how I have it now, yellow to battery, red to ignition. With that setup, the Visteon HDZ actually gets power on the red wire 5 seconds before the PC powers up, since the M2-ATX has a 5-second power-on delay. It's a simple matter for me to change the wiring, if you think that will make a difference.
    As for iGuidance, yes I'm using it, on COM2. However, iGuidance does not automatically run when RR starts, only when I click on the navigation screen the first time. If I never click the navigation button, iGuidance doesn't run, and I still get these HD radio errors.
    I didn't get to do any more experimenting yesterday, so I will have to wait until I get home from work tonight to mess with it. Thanks for your help.
    -- Kevin
  3. #933
    MySQL Error
    Oct 2004
    at hibernation, ignition goes away, but the PC isnt off yet, it has to execute the hibernation procedure
    its ur wiring
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #934
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by mitchjs View Post
    its ur wiring
    OMFG, I have it that way also......... that would explain why when I come out hibernation the d@mn thing doesnt respond. That also explains why sometime the PC is constantly trying to reinstall it.
    UGH, another set back in my install. The HD radio was one of the first things I installed so getting through all the wires is a ******..
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #935
    MySQL Error
    Oct 2004
    kross, i added a tiny bit of code, that will give u a more detailed failure info...
    like if the port is in accessable... ie iguidance grabbed it
    see at resume, if igudance running, even though it was connected on com2, might try to grab com1, make sure u DONT have iguance running at all, when u test this
    just to be sure
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #936
    Jun 2008
    Seattle, WA
    Okay, I'll test out changing the wiring tonight when I get home. I'll also make absolutely sure iGuidance isn't running. I'll rename the .exe or something, just to be sure.
    Thanks!
    -- Kevin
  7. #937
    Jun 2008
    Seattle, WA
    Changing the wiring seems to have done the trick! I'll know for sure after a few days, but it looks promising.
    Thanks!
    -- Kevin
  8. #938
    MySQL Error
    Oct 2004
    in RR, hd is on when RR is running, to all quick source changes, there should close to 0 wait for any source change. one thing of note, power is controlled via DTR line, so tecnically u can wire YELLOW/RED to 12v constant, and the PC still controls the power
    danielkh, the radio isnt actually ON, when the PC is on, thats just a simplicity statement
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #939
    MySQL Error
    Oct 2004
    Quote Originally Posted by kross View Post
    Thanks!
    -- Kevin
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #940
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    In DFX4 I am unable to change the band of the radio. AM/FM...It doesn't do anything, Skin issue?
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 08:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 02:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 06:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 09:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 03:48 AM
