Page 97 of 139 FirstFirst ... 4787888990919293949596979899100101102103104105106107 ... LastLast
Results 961 to 970 of 1387
Thread: HD Radio Cables READY!
  1. #961
    MySQL Error
    Oct 2004
    yea, maybe some OTHER application is grabbing port...
    or printer is set to serial port, or some odd ball device
    with out knowing anything about your pc, its basicly that simple
    hdpcr should just work...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #962
    Oct 2006
    Midlothian, VA
    My PC is as follows:
    D945GCLF2
    1 gig of ram
    Visteon HD radio attached to Radioshack USB to serial
    120gig hard drive
    EBY701
    Garmin 20x USB receiver
    GMPC
    Running RR latest build and DFX4
    Win XP SP3
    I noticed when I looked into the device manager the com port and printer port were grouped together as 1 com port. I always have used hdpcr to test the radio, and it works with the visteon display as well. Other then that, I don't know how else to troubleshoot this problem.
    The only reason this is an issue for me is whenever the USB to serial comes back from hibernate, it clears the winamp playlist. I searched in the other forums and found it due to a hardware issue, so I tried hooking it up straight to the serial port to see if that would fix it. Other then this, it's just an annoyance and the cable does work.
  3. #963
    MySQL Error
    Oct 2004
    the hibernation, winamp issue to me have NOTHING to do with each other...
    winamp's playlist is saved in the winamp dir in the "winamp.m3u" file.. make sure its not set to read only
    i dont know what you mean by printer and com port grouped as 1 com port...
    but sounds like there is nothing to troubleshoot, just solve the problem...
    sounds like the comport isnt free
    i assume you dont have a printer...
    use say hyperterm(or a better terminal program) and make sure the comport opens
    and is free... if it its, hdpcr should simply work
    (i use brays terminal [http://braypp.googlepages.com/terminal])
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #964
    Oct 2006
    Midlothian, VA
    I'll try hyperterm and see if I can't figure out what's grabbing the com port. I can't see any other programs grabbing it as I have nothing else running, but I'll triple check anyway.
    The reason I said it was that was because whenever I resume from hibernate, the moment the radio switches on, I lose the playlist. Otherwise, it would still be there. I'll also check to see if its read only.
    Thanks.
  5. #965
    MySQL Error
    Oct 2004
    well, in RR, the playlist is stored by winamp
    if winamp cant save it, you're gonna lose it
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #966
    Dec 2005
    what is the purpose of the RCA to 3.5mm cable? someone please explain. Also, did Mitch ever make the RCA to USB cable for an "IN" for those who ran out of "IN"s on their sound card? I'm trying to figure this all out before I buy a new USB sound card. I would rather use USB IN as opposed to LINE IN so I can plug in some other things that I need.
  7. #967
    MySQL Error
    Oct 2004
    blackrsx, HU?!?!?!?!?!
    its for the audio.. what else could it be for?
    USB IN, there is no such thing... doesnt exist in real life
    i do make a USB CONTROLLED/POWERED line in selector
    http://store.mp3car.com/USB_Audio_Se..._p/aud-003.htm
    a audio to usb audio is a CODEC device, and i dont make anything related
    due to the fact, im not happy with ANY of the existings USB CODECs
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #968
    Dec 2005
    hI mitch, I was just trying to determine if I get the silverstone DAC if it would allow me to connect the visteon as well. I was reading that the silverstone would override any onboard line-in's or other sound card's line-in's. As for USB IN i was referring to one of your earlier post on page 1. Maybe I was confused. Anyway, could you verify what I just wrote if I can still use the visteon with a silverstone?
  9. #969
    MySQL Error
    Oct 2004
    blackrsx, I dont know....
    that is a audio out device, as far as i can see, it has no inputs
    dont your carpc have onboard audio?
    what u using a laptop?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #970
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Ok... I have tried not using the winamp plugin. I am still getting a quick crackle in the speakers when RR loads. If i unhook the HD radio RCA's it goes away. At least it's somewhat isolated. I assume part of my problem to be that the line in is most likely not muted when not in use. I know you have no knowledge of the KX drivers, they are somewhat straight forward with some twists. The control over the level of the line in is the AC97 Level. I sitll here audio on line in even if the "line in" level in the mixer is muted (KX Mixer). I figure using winamp line in plugin would be benificial in my case. How do I get the "Adress" for the line in to enter into the RR settings and for winamp?
  1. PC Card for HD Radio
    By Spotted in forum General MP3Car Discussion
    Last Post: 09-03-2008, 07:01 PM
  2. HD Radio
    By skyhawk2114 in forum StreetDeck
    Last Post: 06-04-2008, 01:17 PM
  3. HD radio in my BMW
    By DAMBRO24 in forum Car Audio
    Last Post: 11-14-2007, 05:19 PM
  4. Someone here has be be able to crack this HDRadio for the car!
    By Kamakazie2 in forum Hardware Development
    Last Post: 09-20-2007, 08:04 PM
  5. HD Radio?
    By peecee in forum Car Audio
    Last Post: 12-31-2006, 02:48 AM
