The circuit gets powered from the V1 accessory port.Quote:
Originally Posted by contaygious
Printable View
True! :lol: But he wins more from new customers who want to hook it up to their CarPCs. Having that option is just good PR. tj!2k4 just bought one and fantomas and I are planning on it.Quote:
Originally Posted by drait
I am planning on it now that it looks possible to integrate into the PC
Nope, it's the simple "homebrew" interface I'm working on that is the issue.Quote:
Originally Posted by tj!2k4
I can almost guarantee you that the software works 100% with the following:
-the six-transistor design cable like the one here:
http://home.comcast.net/~sllewd/pcware.htm
which is the same design available for purchase from here, as the CT-29A:
http://www.rtsars.com
-The Valentine interface from http://www.ttl2usb.com
However, it would be nice to have a simple desing using few components. Also, the interfaces above definitely won't work with the mute function I'll be adding, without some modification.
Well, I hope he isn't mad about it. Someone who isn't careful could definitely mess up their V1, and then send it in for a warranty repair or something. However, it would be really nice to get his input on the project. I know he uses some kind of software, and interfaces to a laptop to do testing on the V1s...Quote:
Originally Posted by stoodo
I'll try to work on this some more tonight...
Jim
Hey Jim - just looking at the CT-29A "Programming Cable DB-9 to 3.5mm Stereo Plug" - one would just need to snip the stereo plug and replace w/ RJ11 then (obviously paying attention to the correct wiring order), correct?
$25 seems a good price rather than building your own. But mute functionality would also be very nice if you're going to these lengths to integrate the V1 into a car PC setup.
$10 + $7 shipping and already has the RJ11 for the electrically challenged, but as Jim said, no mute at this point..Quote:
Originally Posted by jimbonzzz
That, or build the "Radio Cable to Valentine One adapter from my page, which basically adapts the 3.5mm plug to the RJ-11...Quote:
Jim
I agree, but where are you seeing this $25 price?Quote:
Originally Posted by Arathranar
Look in the Alinco cables under the DR-605 heading.
Edit: I also see it in the Icom cables section.
Stupid question, but the TTLUSB cable is.. USB.. correct?
