Page 11 of 36 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 351
Thread: Valentine One to a PC
  1. #101
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Quote Originally Posted by tj!2k4
    $10 + $7 shipping and already has the RJ11 for the electrically challenged, but as Jim said, no mute at this point..
    That price is just for the TTL2USB cable that goes from the 'box' to the V1. You still have to purchase the TTL2USB box itself (CT-1), which is $39.
    So for ~$50 (not incl. s/h), it would be a plug-n-play affair, minus any mute capability (unless the CT-1 is designed to pass this signal on to the mute line).
    That vs. about $5-10 in parts from RatShack/Fry's/Digikey/Mouser. That is, depending on whether or not Jim's final design is still able to be made from commonly available components.
  2. #102
    Newbie jimbonzzz's Avatar
    Mar 2005
    OK guys, here's the revised interface, tested and working (for me):
    http://www.kc8unj.com/radar/v1_int_d.gif
    Note, the transistor is now a 2N3904 NPN. There's also a few more components, hopefully there won't be as many problems with this design. Should be pretty easy to build, I just modified my other interface. So who is brave enough to be the first one to try it?
    One other note: I changed the "remote display tricker" resistor to a 3.6K, which I think is the actual value. If you've been using a 4K, it should still be fine as long as it turns the V1 display off.
    If someone gets this working, let me know and I'll update my webpage with the new schematic.
    Good luck!
    Jim
  3. #103
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Awesome Jim, thanks!
  4. #104
    Oct 2004
    Quote Originally Posted by drait
    Missed that part, thanks for pointing that out..
  5. #105
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Cool... If i had a V1 i would try it out. Post your results guys
  6. #106
    Mar 2005
    I just updated the software: Software One version 1.1.0.
    I added the mute capability, and I went ahead and changed the schematic on the website to the latest version that I posted earlier (revision D) to support the muting. I also have a little more confidence in this design...
    It also minimizes to the system tray now, and pops up when there is an alert.
    I added a "Settings" dialog with the following options you can configure:
    -Auto Minimize after alert, delay XX seconds
    -Auto-Mute the detector after XX seconds of a constant alert
    -Auto-Connect attempt on program start
    -Auto-Minimize on program start
    -Keep Software One on top of other windows
    If you have any questions, let me know. I tested it pretty thoroughly, but if you do happen to find bugs let me know.
    You can download it from my page here:
    Have Fun!
    Jim
  7. #107
    Dec 2004
    NorCal
    Quote Originally Posted by jimbonzzz
    Dangit, didn't catch the update in time before RatShack closed Don't have any NPNs...
    Will hit up RS or Fry's first thing tomorrow and let you know how it goes.
  8. #108
    Any chance you could make the source available? That would allow it to be adapted/integrated into car frontends in optimal ways. I'm thinking of RoadRunner since that's my frontend of choice since it does everything I want and is open source so I can tweak it if needed
  9. #109
    Mar 2005
    Florida
    Have Fun!
    Jim
    Thanks for the update Jim. Now I just need to attempt another try at building the circuit.
  10. #110
    Mar 2005
    Quote Originally Posted by Arathranar
    Honestly, I wasn't planning on it...
    Let me take a some time and get a better feel for the systems you guys are running. If necessary, maybe I could eventually meet you half way, and do an API release or something like that.
    Jim
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
  3. HU selection with CAR PC in the future...
    By Oracle in forum Newbie
    Last Post: 04-28-2004, 04:02 PM
  4. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
