Page 18 of 36 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 356
Thread: Valentine One to a PC
  1. #171
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Quote Originally Posted by jimbonzzz
    The current code is VB, so it is basically confined to Windows really couldn't be "ported" in it's current form. But, I'm not beyond eventually rewriting at least the libraries in something that could work across different platforms.
    Jim
    There's always the dead Gnome Basic project, or also Mono, if S1 is built on the .NET framework.
  2. #172
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by drait
    I think tj!2k4 just bought a pre-assembled CT-29A cable and jumpered a 3.3k resistor across the data and 12V connection and it works with S1. As far as I know, Jim's the only one with a working homemade interface.
    That is correct. Here is a pic of my handiwork.
  3. #173
    Oct 2004
    Also, a picture of S1 in action and a couple of thoughts/observations:
    Observations
    S1 shows bogeys everywhere it should, except that sometimes it shows too many.
    For instance, there are two spots where I usually get 4-5-6 bogeys with the V1, however, when I passed them, S1 showed 9 bogeys!
    One of the locations is a hospital, so I thought perhaps they were running all of their catscan equipment at once. Then, during my travels I passed the other location where I usually get 4-5 bogeys max and S1 again maxed out at 9! So I did another pass with just the V1 and it showed the usual 4-5 at the one location and then another pass at the hospital, which showed the usual 4-6. Also, one other location in the neighborhood where they have one of those "Your speed is" signs, shows 3 bogeys with S1 instead of just one without it.
    I'm not sure I understand why it is doing that, but I as I said I have observed the occurrence on more than one occasion.
    Thoughts:
    I realize these are mainly cosmetic, but just want to get them out there:
    1.) S1 popped up from it's minimized position every time it detected a signal, however the window titlebar/border are a bit distracting/make it look a bit "off". I thing it might look much cleaner if there was no border on popup.
    2.) The indicator arrows are cut off on the right-hand side. Even when I moved the window a little further to the left of the display, the arrows were getting cut off inside the application.
    3.) It might be a good idea to make the Mute button minimize the display as well until a new threat is detected. With Logic/Advanced Logic modes enabled, that would mean the next credible threat.
    Again Jim, thanks for your assistance and efforts! =)
  4. #174
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    sweet!
    sorry, does the mute work yet for anyone?
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  5. #175
    Oct 2004
    Here's the CT-29A
  6. #176
    Newbie jimbonzzz's Avatar
    Mar 2005
    Jim, looking over the 6-transistor design... I noticed that the DSR and DTR lines are being used for voltage... since your mute circuit is using the DTR line to activate mute, wouldn't it be as simple as removing just pin 4 from this design? There should be sufficient voltage from the RTS, CTS, and DSR lines by themselves shouldn't there?
    I'll swing by the Shack on my way home and see if it'll work the way I'm thinking it will.
    Yep, that should work. Then off pin 4, build the mute section of the other circuit...
  7. #177
    Mar 2005
    It's not...
  8. #178
    Mar 2005
    Quote Originally Posted by tj!2k4
    Observations
    I'm not sure about that either...I'll have to watch for it.
    Thoughts:
    Noted, I'll work on adding this option...
    After my first release, I was working on code to make it so that you can resize the window to any size you want, and it resizes everything else too while keeping everything proportional. I never got it finished, but I'll finish that up too.
    3.) It might be a good idea to make the Mute button minimize the display as well until a new threat is detected. With Logic/Advanced Logic modes enabled, that would mean the next credible threat..
    That is a good idea, I hadn't though of this. I'll add that too!
    Glad you got it working, so maybe people will have a little more confidence in it. I'll keep improving it, thanks for the feedback
    Jim
  9. #179
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Excellent!
  10. #180
    Dec 2003
    oh crap i think i need to go change my pants!
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
  3. HU selection with CAR PC in the future...
    By Oracle in forum Newbie
    Last Post: 04-28-2004, 04:02 PM
  4. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
