Page 25 of 36 FirstFirst ... 151617181920212223242526272829303132333435 ... LastLast
Results 241 to 250 of 356
Thread: Valentine One to a PC
  1. #241
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    hey sorry to bug everyone, but can someone make me a serial cable? I'm dying to install my v1 thanks! email me, aim me, pm me, something!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  2. #242
    Newbie scaccess's Avatar
    Jan 2005
    Hamphire, UK
    Snooper????
    Don't know if it will work but can any one tell me if I cam hok up my Snooper S6 NEO in the same way? Here in the UK the V1 is pretty much dead as most poeple use the Snooper or the Origin B1/2. The snooper carries an standard modem jack on the side and is updated via the phone line through the inbuilt modem. My idea is to query it through its modem if possible as when you update it it also uploads any user stored points for verification. I want to use this function to send the info to the PC as an info stream an then have it show in the front end.
    I'll get there eventually!
    Epox P4, 1.7, LinITX 7", Bluetooth, Wi-Fi, Roadrunner
  3. #243
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    It really depends on the device. You need to see if you can get any information on the communication protocol it uses.
    If the modem port is also used (by the manufacturer) for programming it you may be in luck. If not a deeper hack might be called for.
    It looks to me that the modem is only used for RECEIVING data (like you could hack it to put in your own camera info to modify the database). I would be suprised if you could get realtime alert info from the modem, but you never know.
    You could probably put a device in line between the external Radar/Laser unit and capture signals from that, but that is only part of the functionality.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  4. #244
    Jan 2005
    Hamphire, UK
    Snooper
    The modem is used for sending information as well as receiving it. On update it asks if you want to upload data. If you press yes then it sends your personal inputted points to snooper for verification along with all other users. It is this that makes me think it is possible to output through the modem.
  5. #245
    Mar 2004
    California
    Angry Blown fuse
    OK, I just tried to get schematic D working, and I did it all clustered together to fit inside a DB9/RJ11 connector like someone else earlier.
    Unfortunately, all it did was blow the cigarette adapter fuse, and the SoftwareOne app kept saying that the port was in use (i even tried changing the port to another number, etc).
    Obviously I've done something wrong. Where do I start to troubleshoot this. Also, where can I get additional fuses for the power adapter?
    Thanks!
    Kevin
    Audi A4 Carputer, 80% setup.
  6. #246
    Mar 2004
    California
    I checked over all my solder points, and found a semi-loose one on a serial pin. I fixed it up, and tried again with the second fuse.
    No luck still... SoftwareOne is saying that there is no V1 found. The device and remote work fine, and are not interfered with like previously.
    Ideas?
    Kevin
  7. #247
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    kevlar, what version V1 do you have? I have an older 1.7 that doesn't seem to work with the transistor-based interfaces (built all of Jim's designs from A-D, as well as the 6-transistor design, and also tried a CT29A (thanks to tj; btw, I'm almost done with it)). I'm currently waiting on my USBMOD3 to come in (backordered ) to see if that will prove to be a better solution for older V1s.
  8. #248
    Mar 2004
    California
    drait, I have the latest version, I just recently got it from valentine1.com, so I'd imagine 1.8 or newer. How can I check?
    Kevin
  9. #249
    Mar 2004
    California
    Also I'm in the process of testing the circuit on a breadboard just in case my somewhat newbie soldering joints were crappy...
    Kevin
  10. #250
    Mar 2004
    California
    OK, my breadboard WORKS! I'm very excited that this circuits works!
    Now, I just need to find a circuit board to make this permanent, hopefully something with the ability to put a db9 onboard.
    Any ideas?
    Kevin
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
  3. HU selection with CAR PC in the future...
    By Oracle in forum Newbie
    Last Post: 04-28-2004, 04:02 PM
  4. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
