Page 32 of 36 FirstFirst ... 222324252627282930313233343536 LastLast
Results 311 to 320 of 356
Thread: Valentine One to a PC
  1. #311
    Jun 2006
    Los Angeles
    Your V1 will still have to be on your dash/window as it still has to detect the radar. The virtual display was only meant to replicate the external display you can buy for the V1. This makes your v1 run in darkness so it is less detectable.
  2. #312
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    It looks like this thread is dead at this point, but i'm going to try anyway.
    Did anyone (besides Jim) ever get the schematic to work wiring it themselves? I'm not adept at electronics, but i'm not incompetent either yet I still can't get it to work after checking it over and rewiring (rewiring because I couldn't find anything wrong, but have to assume something is) it a few times now.
    If someone has gotten it to work, can you give me voltage levels at the different points with the V1 connected and on? I'm getting readings all the way back to the serial port (i'm connecting it to a FTDI USB->Serial module, but not seeing anything over the serial port regardless of the baud rate I select. Any info on what serial settings I should be using (using a Mac, so I can't use Jim's or zPilot's software)?
    As a side note, I noticed that the data line appears to be peaking (during startup when everything is lit up) at ~5v. This is in the range of an Analog port so I hooked it up to a development board (Wiring.org.co) and was able to read plenty of data streaming across the port. Anyone know if the data line is indeed an Analog signal and if so what the message protocol is?
    Thanks,
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
  3. #313
    Jun 2006
    Los Angeles
    I tried quite a few schematics and could not get them too work. I will be trying again and making my own box etc. Basically from what I found, the signal is a simple TTL signal that display 5v or 0v for data.
    Here is the protocol:
    [media]http://www.guysoflidar.com/files/v1_protocol.pdf[/media]
    Keep posting here and let me know your progress.
  4. #314
    Jul 2004
    NoVA
    Quote Originally Posted by CityFan86 View Post
    Yeap, they sent me a copy today.
    I tried wiring up my bread board with my (probably incorrect) understanding of the wiring diagram they use there, but I get nothing. When the NPN is connected, the data line reads ~0.6v and all the display is on the V1. If I pull the NPN, the display transfers to my CDU and the data line jumps around like i'm used to seeing (spiky during power up and stabilizes at ~3+v when it is idle).
    -dave
  5. #315
    Jul 2004
    NoVA
    Well since it looks like i'm following a different path to talk to the V1 and it won't (as far as I know) be directly compatible with the software for the interface defined in this thread, i'm going elsewhere to post my findings/work. Anyone that is interested can follow my progress can take a look at my thread in my Front End's forum where i'm working on building a V1 plugin. While the eventual plugin will only be useful for Mac's, the work to talk to the V1 should be applicable to any OS.
    -dave
  6. #316
    Apr 2005
    So do you just plug the box in and that's it? Is there software? I want one for sure, I'll have to get my carpc built first though.
  7. #317
    Oct 2006
    Raleigh
    is anyone producing the V1 usb interface? send me a PM
  8. #318
    Oct 2006
    Raleigh
    Would it be possible to modify IGuidance to mark a location and make the volume for the WAV mute when in your are near that area? this will add the gps function to the Valentine PC softare, of course it is understood that if there is a new radar source in that area you might miss it.
  9. #319
    Aug 2007
    Are these interface cables still available?
    Also, it looked like the communications protocol was posted as one time, is that still available?
    Jay
  10. #320
    May 2008
    Yeah I'm keen but I e-mailed them with no response........ not sure what's happening.
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 04:20 PM
  2. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 02:04 PM
  3. HU selection with CAR PC in the future...
    By Oracle in forum Newbie
    Last Post: 04-28-2004, 03:02 PM
  4. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 01:42 PM
