Page 18 of 56 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #171
    Newbie TurboTronix's Avatar
    Apr 2005
    Canada
    I want one. How much to ship it to Montreal Canada? Will it work with any car (Mazda MX6 1993)? Can you supply prices in US dollars please.
    Will it control both front and back windows (defrost) as well? Also, will the kit come with a detailed instruction guide?
    I am thinking of using only this digital interface and removing my analogue heater/cooler controllers so I want to know if this will allow me to do exactly the same functions.
    T_Tronix
    Don't be a pilot between drivers, just a faster driver in a plane!!
  2. #172
    FLAC Mastero's Avatar
    Aug 2001
    India
    Quote Originally Posted by TurboTronix
    T_Tronix
    Shipping included price ..mentioned above dont know the conversion please try google And it should work for all cars ... unless you have electric heater.
    Front and rear deforst yes .. !
    Cheers
    Mastero
  3. #173
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    i am interested in one of course
    I still have bunch of questions though. I am wondering alot about the servos. I have never worked with them before. Am i hooking the servos up some how to the existing HVAC controlls or do they get hooked up to the actual device that they are controlling?
    Is it true that you are not including any servos?
  4. #174
    Aug 2001
    India
    Quote Originally Posted by antimatter
    Its better to hook the servo to the actual device (Flaps) the existing HVAC controls .. this way you can use a low torque servo and wont stress it.
    Sorry but here in India servos are very expensive
    Cheers
    Mastero
  5. #175
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Dang, looking good Masero. Might just have to pick one of these up from you.
    肚子笑痛了
    S60 Install
  6. #176
    Belgium - Oostmalle
    Another question I want to cleared out before I buy one : if servo's are going to control the flaps, doesn't the original steering for the actuators interfere ? What's going to happen if they do ? eg: In the software you set a temp of 20 degrees, but the original knob is set to 25 degrees ... The servo cannot put the original knob to 20 C, it only works the other way doesn't it?
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
  7. #177
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    im very interested, but im going to wait until some other people get this working on their cars.
    i start university in 2 months, and wont be around too much in the mean time, so im not sure ihave the time for something like this at the moment.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  8. #178
    Aug 2001
    India
    Quote Originally Posted by gyro
    I am not getting your point here ... ? See if you set the unit to cutoff at 20 deg then it will cutoff when the cabin temp reaches 20 deg. this is controlled electronicly by the unit .. all that the servo does in this case is adds hot air to the air that is if you want it. so its got nothing to with the cuttoff temp.
    JCDILLIN : If you want one .. msg me you get a good discount for your help.
    Cheers
    Mastero
  9. #179
    Belgium - Oostmalle
    Quote Originally Posted by Mastero
    Cheers
    Mastero
    Do you disable the original controls then? If your original control is set to 25C and you set the cutoff temp to 20C with your software, the motor is set for 25C (controlled by the original control), and the servo wants to position the motor for 20C isn't it? So the original control and servo are fighting each other or am I wrong here ?
    Regards,
    GyRo.
    Carpc :
    PSU : M2-ATX
    In car : 80% done
  10. #180
    Aug 2001
    India
    Regards,
    GyRo.
    How can u use the original controls and also this unit ... ??
    I dont think you understand how this unit works ... The heat servo has got nothing to do with the cutoff temp setting.. the cutoff will cutoff the compresser at a perdefined temp and the heat servo is used only if you want to add heat to the air flowing ... get it .. !
    Mastero
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 08:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 01:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 08:52 AM
