Page 2 of 56 FirstFirst 12345678910111252 ... LastLast
Results 11 to 20 of 558
Thread: HVAC Control on Car PC through Serial Port.
  1. #11
    Jun 2004
    Graham, WA
    you need any help in the programming part mastero? Im not real great but im working on it I do C++
  2. #12
    Low Bitrate M11VNY's Avatar
    Aug 2004
    Leicester & Reading, UK
    wow! sounds great so when can we take a look at the software! need any testers?? what car have you done this for?? will it work on any car?
    Its down!!!! Sold the Golf so took it out, it's still alive but not installed.
    Progress [-----------] 0%
    Who the Daddy Iz!
  3. #13
    Mar 2001
    You can't bit-bang the LPT port with a USB-LPT adapter easily.
    We had issues using the LPT port for our window/doorlock controller, and we solved it using our DSSC. We don't provide power to the board until after the PC has booted. Hell, it's one of the reasons we designed the DSSC to have that functionality.
    That said, your probably better off just going USB and cutting your losses and doing a redesign. Parallel ports are a dying breed, and it's not wise to develop a product for dying technology.
    Just my .02 cents...
    Check out my carputers:
    DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
  4. #14
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by bergeron76
    Yeh, like lots of abit boards dont' have parallel ports now days The port is also too big on the motherboard, and no one wants to run more cables through their car.
  5. #15
    Sep 2003
    Brisbane, Australia
    I am actually using a parallel relay controller board to do the same thing, except set temp., but have the problem of the a/c starting up on odd occasions when the PC is booting. If yours gets around this, I'll certainly give it a go and can use the relays for other gadgets.
    Keep us posted
  6. #16
    Registered User
    May 2003
    For a USB product to go on production, the biggest one off cost would be buying the USB vendor ID and would cost something like $1,500 - $2000.
    I can understand why some shy away from USB, unless of course its for personal use.
  7. #17
    Jun 2004
    Graham, WA
    whats a USB vendor ID?
  8. #18
    Registered User
    May 2003
    If you go to a USB device property in device manager. On the details tab you see the VID_xxxxPID_xxxx.
    This is the manufacturers VID (vendor ID) and PID (product ID). This is required to be unique so windows can load the approriate driver automatically. The product ID is the product for that vendor ID, so a vendor can have up to 65635 products.
  9. #19
    Registered User
    May 2003
    Heres the VID/PID list >>>
    http://www.linux-usb.org/usb.ids
  10. #20
    Dec 2004
    hmmm im asuming you would have to have a digital A/C unit?
    i have an 05 altima, that has knobs.
  1. Using PC to control lighting.
    By gguy in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:11 PM
  2. Kenwood In-dash Monitors to control pc?
    By DrBuzzo in forum LCD/Display
    Last Post: 12-08-2004, 08:21 AM
  3. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  4. software to control pc from ipaq
    By spud42 in forum Software & Software Development
    Last Post: 11-13-2001, 01:56 AM
  5. Using a pda to control a normal PC
    By All4Norway in forum General Hardware Discussion
    Last Post: 08-27-2000, 08:52 AM
